Question about Toshiba Satellite A135 Notebook
Unable to open windows
When laptop turned on, it attempts to open windows...
But blue screen comes up then the safe mode etc screen comes up...
When you press safe mode, safe mode with networking and the other or the start windows with last config a bunch of commands comes up.
And it all starts over again...
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    You can repair it by using your Windows Operating System disc. Do you have that?
  • emilgram May 11, 2010
    Can you start the notebook in safe mode by pressing F8 when Windows attempts to load?
  • 39 Answers
Try booting into safe mode (hit F8 repeatedly when you reboot until a safe mode option comes up) then if you are able to log in, go to the windows run prompt, type "msconfig" go to startup, disable all, services, disable all. reboot. see if it still does the same, if it doesn't one of those services are causing blue screen. Also try reverting to previous drivers if you did any driver updates, remove any new cards/hardware you might of installed recently.
If you can't get into safe mode, at a copy of any xp disk. boot up from it. (make sure your boot devices are set that cd rom is before hdd in cmos setup) then go to the recovery console "you press 'r' when ou have various option" type 1 for the windows, enter. enter for password unless you previously set an admin password.
Then type "chkdsk /p", let it run also type fixboot, and say yes. reboot and see if this solves your problem.
Posted on Jan 05, 2009
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I have a dell vostro 1400running on Windows 7 yesterday i tried to install and old software for an mp3 player and it said when running it there are some compatibilities problems the laptop shutted down...
Restart the computer couple of times, you will get an option to run startup repair. Use your keyboard up / down arrows and highlight the startup repair option and hit enter. This will run startup repair and should solve the issue.
Mar 01, 2011 | Dell Computers & Internet
I have acer aspire when i turn it on only blue screen come on how can i fix it
Hi !
Blue screen means that your Hard Disk drive is damaged or dead and it cannot be repaired. Solution is to replace new the hard disk.
Good Luck and thank you for using FixYa !
Jan 06, 2011 | Acer Aspire One PC Notebook
When attempting to start my computer this morning it took me to the safe mode screen ("We apologize for the inconvenience but windows did not start successfully. A recent hardware or software change...
open your computer in a safe mode then save important files in pen drive or some removable drives....or scan it in safe mode with updated antivirus......or updade windows or repaire windows using installation process...........this will definatelly works..........
Nov 13, 2010 | Computers & Internet
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
Can't log on
what i can suggest you is to reformat/do a recovery..nothing else....dont waste your time..because you cant load in windows right? its commin only with blue screen...when you select safemode or etc..nothing happen...try with my suggestion..if you have some important files you can do a backup by removing the hdd and put into usb adaptor and plug in any computer that can do a backup....i hope you appreciate it
Jan 05, 2009 | HP Pavilion ze4933US Notebook
MY HP pavilion zt 1000 series just crashed
When reinstalling XP, install in a directory other than WINDOWS. Your My Documents will be safe, unless you have already overwritten it. Other data should be safe.DO NOT FORMAT THE DISK as the installation suggests.
Jun 28, 2008 | Computers & Internet
Toshiba Satellite A135 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
