What capacitor should I order for my outside unit.
I was told that the capacitor was week in my 2009 outside unit. Can this be true? It looked like an easy part to swap, but I can't find a part number to order.
    Genius:
  • 2,432 Answers
The starting capacitor was connected at the one line of the compressor motor then the value was label at the body of he capacitor, like 450v/ 5uf. to determined that the capacitor is totally worn out you will need a analog tester or a capacitance meter. usually if the starting capacitor get bad the motor doesn't run or hard to rotate.
Posted on Nov 06, 2012
4 Suggested Answers
  • 587 Answers
SOURCE: Easy Start Capacitor
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Feb 21, 2010
  • 413 Answers
SOURCE: I JUST BOUGHT THIS UNIT
Yes, if you are talking about a heat pump. It you have an electric furnace inside, the electric elements are for emergency heat. Otherwise, unless you switch it manually at the thermostat, the heatpump (outdoor unit) will run all year around. If you want to use your inside heater (electric heater) just switch your thermostat to "emergency heat" and it will turn on the electrical elements instead of the outdoor unit. This way will make your elec. bill higher tho. The heat pump is much more efficient. Hope this helps you , have good day
Posted on Jul 21, 2011
  • 387 Answers
SOURCE: Goodman GTH1348821 4 ton package H/P.this unit was
That linve voltage looks a bit high for a 220 volt sytem if thats what it is
Posted on Jul 23, 2011
Outside A/C unit not working
is this 3 phase? 3 phase is diffrent from single phase
Jun 18, 2013 | Goodman CLQ36AR49 Air Conditioner
It is a Ruud UAKA-024JA2 combination of air conditioner and central heater. The outside air conditioner fan stopped running but buzzed. The capacitor is out of order. Do you have instructions how to locate...
Hello, the capacitor is a round or oval metal can that is located in the control pnael of the outside unit. In order to replace it you must turn off power to you unit and unhook the wires that go into the capacitor, but make sure you label them so you remember where they go back. When you unhook the wires take a screw driver with a insulated handle and put in across the terminals of the capacitor to discharge it. Then just remove and install new one.
Aug 24, 2011 | Heating & Cooling
I have Goodman A/C Unit which was working yesterday morning but the outside unit will not come one. I was told to locate the reset button but unable to locate the button.
This could actually be a capacitor issue and pressing the reset button wouldn't do much good. Go to the back of your outside unit and look inside the access panel with the electrical warning sticker on it; if the capacitor is bowed up at the top, it needs to be replaced. If it turns out to be the capacitor, follow this link for a new capacitor replacement kit, it will save you hundreds of more dollars than calling an HVAC repair company to charge you an arm and a leg. The kit also comes with the proper tools and parts needed as well as detailed instructions on how to replace the part yourself. http://hvacrepairkits.com/index.php/content/article/68
I hope this helps!
Aug 17, 2011 | Goodman CKL36AR36 Air Conditioner
Air conditioner stopped working. Its not cold. Blowing outside air in.
Check the capacitor.
90% of the time with AC units, it's the capacitor with.
They are cheap and sometimes found in local stores.
L8ers
Sep 12, 2010 | 2009 Honda Accord
My outside a/c condensing unit's fan runs, but inside vent air is not cold. compresser may not be running. inside vent air was cold last week. Janitrol ckj361ab is model # of outside unit.
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Jun 17, 2010 | Heating & Cooling
I have a CK49-1B and it stopped working yesterday. I can hear a buzzing noise outside at the unit. The fan won't spin. I have tried the inside breaker and that seems fine. Thoughts
That sound like it may be the capacitor. Luck for you it is around a $20 fix. A compressor could run you hundreds. Turn off the power to the outdoor unit and take off the electrical cover on the outdoor condenser. There should be a part that looks like the pic below. If the top is bulged its a true sign of a blown cap. If it looks fine, take it off and get it tested. If you have a multi-meter that reads micro farads you can test it yourself. There is a sticker on the side of the cap that will give you a uf rating. Probably around a 35/5. Grainger carries these otherwise you can order them online. Let me know what you find. 2e66ec2.gif
Jun 05, 2010 | Goodman CLQ36AR49 Air Conditioner
It simply stopped. The box outside is switched on.
I am going to assume you are talking about the outside condenser. If the thermostat is calling for heat and the furnace blower is on, you may want to check the capacitor inside the outside unit. Disconnect the power to the outdoor unit and open up the electrical compartment. There is either a round or oval silver cylinder inside by the contactor. That is the capacitor. If the top is buldged it is a true sign of a capacitor failure. Remove the cap and take to your local HVAC Wholsaler or contractor to have them replace it. It is a very common part and should cost you around 15 to 25 dollars. Let me know if this helps.
Jun 04, 2010 | Heating & Cooling
Where is the capacitor located on a coleman heatpump
If you're talking about the outside fan, look where the wire goes into the outside unit. The capacitor will be somewhere near the circuit board and will be round or oval and metal or plastic. If you're talking about the inside unit it will be with the electrical control in the air handler. Write down where the wires go. The terminals on the capacitor will be marked and for the outside unit you will either have 1 that runs both the fan and compressor or a seperate one for each. If you have 1 that runs both the wires must be reconnected to the right terminals. They will be marked COM, FAN, HERM(stands for compressor). Take the old one with you to get a new one. Let me know what you find.
May 04, 2010 | Coleman Heating & Cooling
Samsung LCD TV (Model LA40R71BD) - Trouble turning on. Been told a matter of changing the power module...true? If so, where is the best place to order one?
Actually you might not have to change the Power supply, it may be repairable,If you open the unit and look at the power supply look for too capacitors that have become puffy on there tops. All capacitors should be flat on top.Just in case you are not sure what a cap looks like they look like little batteries standing horizontaly on the board. The value of these caps should read around 1000uf at 10v.
Replace them with 1000uf 16v. Also note the the caps are polarized + and - make sure you install them the same way, the white strip on the caps is the ground pin.
Dec 03, 2009 | Televison & Video
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
