I have acer net book and it keeps saying no bootable device insert boot disk and press any key
  • 7,627 Answers
Try a "Cold-Start", Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug inti AC outlet,Push on/off button and Start normally. If that fails, Re boot while tapping F-8 to view options. At boot try esc or F-2. I don't know your Make ,Model, or OS? You didn't give much info so it's hard to make a informed suggestion. Did you do a install or upgrade your OS?
Posted on Nov 05, 2012
  • 38 more comments
  • jeremy Nov 06, 2012
    its a aspire one d270-1401 no disk drive on this
    no upgrade to os
    f8 wont do anything
  • max carson
    max carson Nov 06, 2012
    Your machine is obviously not "seeing" your HDD's OS. If you do not have a Boot Disk or a Factory recovery disk you can download a Windows Repair disk ISO, if I new what OS you are using. If you supply your ACER model and OS I can better assist you.
  • max carson
    Remove any media from the machine, DVD,CD, USBs etc, before you try any repair.
    model aspire one d270-1401 where do i find the os at thankyou
    and i have no place to put in a diask
    aslo says media test failure check cable
    ok i did that
  • max carson
    I suppost you could download to a USB, if you have one,try this sitehttp://bootfromcd.com/data-recovery/wind...
  • max carson
    Let me know how it goes.
    ok I will try that how do i go about seting it back factory settings
  • max carson
    Take a look at this "how to" procedurehttp://bootfromcd.com/data-recovery/wind...
  • max carson
    You will nedd a 2GB or larger "Thumb Drive" to download the ISO program to, If your machine ID's the drive, after getting to the point where it says "Press any Key" It should run the Repair disk/program loaded on the USB, I hope.
  • max carson
    If you cannot get the download from the previous link I supplied you try this link for a ISO Windows 7 repair disk download:http://forums.mydigitallife.info/threads... scroll down the page Look for a heading "code", under you will find Windows 7 32 and 64 bit versions in english.
    thank you i wil try this and let you know how turn out. thanks agin
  • jeremy Nov 07, 2012
    i change the hard drive and it wont let dowload the on the usb flash drive. i got 16gb sandisk
  • max carson
    max carson Nov 07, 2012
    I don't understand? i change the hard drive ? what hard drive?
    it wont let dowload any thing on usb i got its i have open file. our desk top wont open it
  • max carson
    I don't understand? "it wont let dowload any thing on usb i got its i have open file. our desk top wont open it, E-MAIL ME AT:desk.maxcarson@hotmail.com
    I have it down laded to flash drive usb but when i hook it to the net book it still says the same thing needs boot disk and press any key. if you have any suggestion it would be help full thank you again
  • max carson
    Reboot and start tapping F-12 repeatedly when you push the on/off button, we are trying to get to the Boot Menu to force it to load from th USB, when you get to boot menu highlight boot from USB device, that will point the computer in the right direction. At boot you may see a balck screen with a blinking cursor in the top left, tap any key A-Z.
    try that, and it goes back the screen insert boot disk and hit any key... and it say media test failure, check cable
  • max carson
    max carson Nov 08, 2012
    Do you have a Repair Disk? Do you have windows 7, 32 or 64? You can download a repair disk online. I don't know your OS?
  • max carson
    Try Cold Start follow the procedure to the letter, when you push the on/off button to on , Start tapping the "esc" key quickly moving through the F keys one after another , as in, TURN MACHINE ON, FIRST, TAP THE esc, moving right to F-1, F-2 all the way to F12. One after another. What we are trying to do is FORCE the machine to respond to any input. If it does let me know. Or try to Boot from HDD, if that option is available. REPEAT PROCESS TO GET A RESPONSE.
  • max carson
    IF YOU GET A RESPONSE TO ENTER RESTORE/RECOVERY, ENTER RESTORE/ RECOVERY.
  • jeremy Nov 08, 2012
    I have i download repaier disk to usb flash drive. idownload windows 7 . 32
    it still goes to the same screen as before. enter boot disk
  • max carson
    Did you do a Cold Start before EVERY attempt to repair? Remove the battery during these repair procedures that will remove power FULLY every time you unplud the machine from the AC outlet. When you push the on/off button to ON start tapping repeatedly if no response try alt esc, F-1 ,F2, through F12 Quickly at PRE-BOOT.
  • max carson
    First alt and F10, tap both at the same time, we are trying to force a response from the machine, any respone at this point.
    tryed all of that nothing alt f10 nothing to goes to screen saying exiting pxe rom no bootale devive insert disk and press any key
  • max carson
    When you press any key? At boot or pre boot, do toy get a QUICK black screen with a whit cursor in the top left corner? If so tap any key on the keyboard. Obviously we are not getting the MBR on the HDD. Can you test the HDD on another machine or go to a Computer store. I have a ULTRA USB to 2.0 IDE/SATA Adaptor Cable to test HDDs. That said, it could be a HHD problem, can you remove the HDD and Memory mods. and re-seat both?
  • max carson
    You have verified the downloaded WINDOWS REPAIR DISK is readable, You can insert it in a working machine of the same OS and see if it Auto Loads, POPS UP on the desktop asking what to do, as in RUN etc.
  • max carson
    Refresh my memory, You have Windows 7 32 bit? Let me know the download must be your EXACT OS. Or it will not work.
    put in a new wd scorpio blue hard drive cause the one it came with was shoot. its 500gb/go and sata 8mb mo cache. doesnt have any thing on hard drive why wont windows go on it then
  • max carson
    Do you have a Windows OS disk? A copy download or purchased? You can download a copy from here:http://www.mydigitallife.info/download-w... It's a ISO that must be burned to a DVD, USB The program is some where around 3GB, REMBER this copy does not come with a PRODUCT KEY CODE that has to be purchased.
  • max carson
    Have you ever installed a OS before? If not you may want to reveiw a tutoral on loading OS.
  • max carson
    32 bit or 64bit? processor?
    ok i will thankyou i wil let you know how it turns out
  • max carson
    OK , do let me know.
  • 206 Answers
SOURCE: when I turn on my acer 5115 it says no bootable
it is possible that there is a mistake in somewhere in BIOS. when booting go to BIOS, and look for booting devices. As a primary booting device should be your HDD, or ODD first and HDD second.
apply these changes and see if the problem is fixed.
if it isn't, it is very likely that your HDD is not working anymore
Posted on Nov 14, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
pappapumpdaf
  • 635 Answers
SOURCE: for Acer Aspire One Net
Your netbook is trying to boot from your Lan/Ethernet connection since It can find no working hard drive to boot from. This usually means that your hard drive has failed.
Also remember that your netbook will try to boot from other drive types including your SD card, USB Memory Stick and even a Magic Jack if you have one inserted in the flash memory slot or USB slot while rebooting the PC.
Many people have mistakenly assumed that their Netbook is messed up because they forget to remove all flash and memory sticks before rebooting.
Posted on Oct 31, 2010
  • 61 Answers
SOURCE: my acer one net book
if ur OS is good, i mean not formatted or u just formatted the system. check ur bios, boot devices, put ur cd/dvd drive on top then save and exit and restart.
Posted on Dec 06, 2010
SOURCE: i have a acer laptop
Its either 1 of 2 problems you will have to check to see if your hard drive has fallen out of place by un-doing the screws thats holding the hard drive cover in place to check if its in tact then your hard drive has developed a fault and will need to be replaced, if your notebook is still in warranty i would recommend contacting acer to have them replace it for you, if its not in warranty then you will have to buy a new hard drive and softload it using the key you have on the back of your system.
When it says no bootable devices it means that your notebook did not detect your hard drive to boot up from, instead its asking you to put it back in or put in your operating system cd to boot from that, if you need further assistance please ask and rate me Kronoguy
Posted on Jul 07, 2011
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
What is a bootable device for zg8 ?
it meens it can not find hdd or can not find its windows to boot up.
so its asking for its windows disc.
Apr 26, 2014 | Acer Aspire One Netbook 8.9" Notebook
Ok 1. acer; aspireone 2.Wont boot up 3. PXE-E63:Error while initializing the NIC 4. PXE-MOF Exiting Intel PXE ROM 5. No bootable device--Insert boot disk and press any key. Thic pc has vista on i
switch to boot devices (F2....F8,)do this as soon as you press power button.keep pressing to bring up bios disable all bootable items in list except cd rom.give this a try good look
Dec 12, 2013 | Acer Aspire Computers & Internet
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
It keeps tellin me no bootable device-- insert boot disk and press any key... i also dont have a disk drive all i have is a ubs flash drive spot
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 17, 2012 | Acer Aspire One D257 Netbook
My acer aspire one netbook AOD257 keeps telling me no bootable device insert boot disk
Oct 17, 2012 | Acer Aspire One Netbook 8.9" Notebook
My acer one net book just says no bootable device insert boot disc press any key
Dec 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire 4810t says no bootable device
enter BIOS - you will see a mesage when you first turn on laptop tellign you to press a key to enter setup. Do this and make sure HDD is listed. if it is, you might have todo a recovery.
Turn on laptop, then immediatly press ALT + F10 keep finger on ALT and press F10 a few times, this will start the recovery process. some ask if you want to re-install windows or full factory reset. Windows install will only repair it - full factory reset will delete any data you have! so be careful
Feb 14, 2010 | Acer Computers & Internet
When I turn on my acer 5115 it says no bootable
Nov 14, 2009 | Acer Aspire 5315 Notebook
Initial set up problem. Acer net book
this small laptop does not comes with cd rom,So you can arrange a USB Optical drive.In bios setup please check for boot sequence is to be set for usb boot device.Now insert the bootable cd or Operating system cd with boot files & it ill works
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
