My Acer one aspire d270 keeps saying no bootable device insert boot disk and press any key
  • 236 Answers
SOURCE: When I turn on my
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Posted on Feb 14, 2011
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
leecom72
  • 4806 Answers
SOURCE: acer aspire one
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Posted on Aug 06, 2009
  • 5 Answers
SOURCE: Acer aspire one mini notebook. NTLDR is missing..
If you don't have documents, pictures, etc on the hard drive that you need to backup, try running system recovery by doing the following (not sure if this works on the version with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
Posted on Oct 13, 2009
  • 206 Answers
SOURCE: when I turn on my acer 5115 it says no bootable
it is possible that there is a mistake in somewhere in BIOS. when booting go to BIOS, and look for booting devices. As a primary booting device should be your HDD, or ODD first and HDD second.
apply these changes and see if the problem is fixed.
if it isn't, it is very likely that your HDD is not working anymore
Posted on Nov 14, 2009
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
What is a bootable device for zg8 ?
it meens it can not find hdd or can not find its windows to boot up.
so its asking for its windows disc.
Apr 26, 2014 | Acer Aspire One Netbook 8.9" Notebook
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
It keeps tellin me no bootable device-- insert boot disk and press any key... i also dont have a disk drive all i have is a ubs flash drive spot
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 17, 2012 | Acer Aspire One D257 Netbook
My acer aspire one netbook AOD257 keeps telling me no bootable device insert boot disk
Oct 17, 2012 | Acer Aspire One Netbook 8.9" Notebook
When i turn on the acer aspire one D255E it says chack cable connections no bootable device insert boot disk and press any key
it could be that the BIOS is set to boot from cd/dvd instead of boot from hard disk. if so, resetting the BIOS to default values might clear the problem. if not then check that you have not left another disc in the optical drive rather than a bootable operating system disc.
another possibility might be that, internally the hard disk drive is not properly docked into its sata port.
Nov 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, I cannot boot my acer aspire 5315 laptop, No boot filename received. PXE-M)F: Eciting broadcom PXE Romm. No bootable device. Insert boot disk and Press any key. Please can you help. Mant thanks
It looks like your hard disk went invisible, and BIOS is trying all alternative boot options before it says that there's no boot device available.
I'm afraid that the most probable diagnosis is that the hard disk is broken; anyway you'll need hands-on service to establish what's wrong and what can be done.
Oct 18, 2010 | Acer Aspire 5315 Notebook
When I turn on my acer 5115 it says no bootable
Nov 14, 2009 | Acer Aspire 5315 Notebook
Jul 10, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
298 people viewed this question
David Payne
David Payne
