Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Doesn't stay on
My mixer is working inconsistently. At each setting the mixer will start for about 10 seconds and then stop.(Pulse when I don't need it)
  • 2 more comments
  • Anonymous Jan 18, 2009
    Mine starts in very high speed regardless of the setting, goes atthat speed for a few seconds and then shuts off. If I set it to off and then into any speed it repeats the same problem.
  • smit73 Feb 20, 2009
    Mixer starts in high speed and then shuts off after about 10 seconds. It starts at this speed regardless of what speed you set it on.
  • lisahoss_81 Mar 31, 2009
    Same thing as above... It starts for a few seconds and then shut off until you swich speeds.
  • naunson2002 Apr 03, 2009
    looses power, if you move the speed up and down it will work for 10seconds then it will stop. I unscrewed the back to open the motor and it seems like it is grounded. if I press the handle of my screww driver to the plastic black cover of the motor it eill run in high speed. iam vaery disappointed, I used to own a kitchen aid mixer that was given to me by my grandma. used it for 10 years, no problem. I hope more people will stop buying their products. its a rip off !!!
    Problem Solver:
  • 12 Answers
They are junk! If you are hands on savvy look for my other posts on disassembly. Then, make sure grease is not seaping into the motor area and then clean every contact using contact cleaner. Filing the "points" is also worth a try. Lately, you can't buy one of these that isn't junk. Have you seen all the posts??
Posted on Mar 16, 2009
How do I fix a kitchen aid mixer that possibly shorted out?
Buy a new one quick. Or hide. Spent . electrical engineering. And supply of new diodes resistors and capacitors are needed.
Apr 17, 2016 | KitchenAid New Professional 5.5 QT...
My Hobart D-300 keep stop after running about 10 minutes and stay idol about 5 minutes then I can push start button to run another 10 minutes, it seam like control unit stop after it getting over heat and...
If your mixer's motor was built by Hobart; there are thermsiters built in to the stator's windings that can cause this problem. Check the amp draw while it is running. Also if your are over loading the mixer or using the wrong speed,, that will cause an over heating problem. You should be able to get on the ITW Food Equipment Group / Hobart web site(s) and get capacity chart.
Mar 01, 2015 | Hobart Food Mixers
Mixer works fine with speeds up to 6, but changing to 8-10, speed stays the same.
Sometimes can be caused by running too fast on the lower speeds. Should be 13 to 15 revolutions in 15 seconds on speed 1 then a slight increase only on speed 2.
Aug 01, 2013 | KitchenAid K5SS Heavy Duty Commercial...
How do I repair the speed settings It only goes on fast speed.
The screws are roughly 8 turns in from fully out when starting to set the speed. On the lowest speed 13 revolutions of the planetary in 15 seconds is a good speed.
Dec 05, 2012 | KitchenAid Artisan Series Stand Mixer -...
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
I have a Kitchen Aid k45ss that was dropped a few years ago. I works fine but the speed switch doesn't want to stay in the off position so we have to unplug it. I opened the unit and the switch...
When you said "the speed switch doesn't want to stay in the off position", you meant to
say "the speed switch in the OFF position does not turn OFF the mixer", or "the speed
switch physically cannot be moved to the OFF position"?
In any case, try to adjust the mixer speeds.
Obtain a copy of the K45SS Repair Part List from Kitchenaid.com.
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 21, 2011 | KitchenAid Food Mixers
Kitchenaid speed controller (don,t work
You need to adjust the mixer speeds.
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Speeds don't increase after 6
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 03, 2011 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
121 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
