go HERE, he/i will tell you how you can get it repaired free. this can be fixed but it requires a lot of time and patients..
i dont think there is enough space here to explain fully how to restore the gps....you cant make it any worst but why waste your time if you can get it done for free.
take the unit outside so that it has a clear view to the open sky, turn the unit on, then push the reset onthe side(you need a paper clip) youll know its reset once you see the magellan logo screen with the black loading bar on the bottom. let in sit outside to Aguire the satellites. this may take upto 30 minutes. if that does not work, you can try the latest update. bill
Magellan web page has a firmware upgrade for your 3250. It is Version 4.86 unless you already have it. If that doesn't help, go to there support page and at the bottom you can see if one of the questions on the page is something that is similar to your problem. If not you will be able to ask a question yourself. Good luck.
You probably just need to reset it.
Magellan Maestro models- the location of reset button is on the left, right, or bottom side inside a small hole. Use an object to apply pressure to depress the reset button. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on.
You may need to update your firmware. Go to this site http://www.magellangps.com/support/
select your product family, model, and then press the submit button. Firmware updates are located in the updates/upgrade section.
This should solve the problem. Good luck. If this helps, plz rate it fixa. Thank you kindly.
