Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I hear the refrigerator running but it is not cooling
  • Anonymous Jan 06, 2009
    The freezer door on my Kenmore side by side was left partially open all day and now the freezer nor the refrigerator will cool, but the motor is running in intervals
Running short time , refrigertor not cooling very good
Posted on Jan 05, 2009
GE refrigerator model #GSS22WGMD wont cool at all but fans run but don't hear compressor
If possible, try by passing the thermostat. If it starts up the t/stat is bad.
Feb 25, 2015 | GE Refrigerators
My fridigaire FFUS2613LS is not cooling
Good Afternoon Timothy,
I understand your Frigidaire refrigerator, model# FFUS2613LS, is not cooling. I also see that you hear the motor running, can't feel the fan running, and it is not cooling. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the fan is not running and your refrigerator is not cooling. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire FFUS2613L Side by Side...
Dometic DM2652 quit working on elec,tried gas worked for a little than quit,wont cool can hear it running.
If you can hear it running and it sounds like it is gurgling or boiling then it is you cooling unit that has leaked. Your cooling unit is charged with hydrogen and ammonia. When the hydrogen leaks it causes the ammonia to boil more rapidly, hence what you hear. You will require a new cooling unit for your refrigerator. This is something that can be done by anyone in just a few hours with no specialized tools needed. You can give Arcticold a call toll free (1-888-782-6665) or check out our online Store I have also attached a how to video for the installation of a Arcticold New Lifetime Warranty cooling unit. 3a202669-372c-42db-9d46-dcb343b69e0b.jpg
Mar 11, 2014 | Dometic RM2620 Refrigerator
The frigerator & freezer are not cooling properly . i hear the compressor running . i have also diconnected cleanned inside and out but still the unit is not cooling properly . even on higest settings
If the compressor is running almost all the time (and the compressor sounds ok - no pinging/clunking),
then your side-by-side has developed a coolant leak.
When a system is low on coolant, the thermostat detects the warm condition of the refrigerator, and
runs the compresor motor in an attempt to cool off the refrigerator compartment, but if there's little
or no refrigerant in the system, the system's attempt to cool off the refregerator/freezer will fail,
with the symptom that the user wil hear the compressor motor running constantly.
May 13, 2011 | Kenmore Side by Side Refrigerator
Moisture is pooling on my refrigerator shelves and I haven't been hearing the defrost cycle run,
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Kenmore Refrigerators
The freezer section of my whirlpool double door refrigerator becomes too cool while refrigerator section does not cool lower than 56 deg F. Setting of Freezer section is at minimum cool (extreme left)...
when you open the freezer door you should hear a fan running, that's what cools your refrigerator section. If you don't hear that fan, that may be the problem. Also if there is frost on the back panel of the freezer that also may indicate a defrost problem, which could cause the same problems
Aug 22, 2010 | Refrigerators
Refrigerator is not cooling, but the freezer is....
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
q
May 08, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Refrigerator not cooling, do not hear compressor
clicking sound is motor protector cuting out compressor drawing to much current replace compressor.
Oct 21, 2009 | Refrigerators
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
