Question about RCA Pearl TH1102 MP3 Player
Internal/External Memory menu? Won't play music?
My Pearl mp3 keeps going to this menu with 2 options Internal and External (memory)
But I have no external memory, and it won't play music.
Help?
  • 8,596 Answers
Pick internal memory unless you have an SD card attached. Then press the "M" button on the side of the player to see if it will change menus.
-Tha Mp3 Doctor
Posted on Jan 07, 2009
My iriver stops then comes on with warped music, then stops again. Now although I know it's charged it will not turn on... Just out of warranty too.
Good morning, afternoon, evening or night; whatever time you are viewing this. What you are trying to say in your request is that your MP3 player stops playing, then comes on for a short period of time with defective music, then cuts off again. There could be a number of causes here. We can eliminate the "battery needs charging" cause because you said that the battery is already charged. But the battery itself may be defective. If that's the case, you will need to install a new battery into your device. Reply back and I will try my best to locate where you find a battery for this product. Another cause to take into consideration is the music file that you are playing. The music files that the iriver 150 supports are: MP3, WMA, OGG, FLAC & ASF. The music file you that was currently playing may not be supported by this device or is corrupted. If so, you need to delete this file immediately. To delete a file, press and hold the > (directional right) button to display the Options menu. Select Delete File to delete the selected file. You can also go to your file manager and manually delete files. On the main menu screen, press the directional up or down buttons and selcet the File Manager, then press the OK button. Next, press the directional up or down buttons again to select either Internal or External Memory, whichever type of memory your file is under. If you do not know what Internal or External Memory is, Internal memory is the memory in your hard drive. External Memory is portable memory for example a Micro SD card, that can be taken out. In the file folder list, press the directional buttons to select your folder or subfolder if you have created one. Once you've done that, press and hold the > (directional right) button to confirm the deletion process. If you are still having problems, try changing the settings for the backlight or auto power. To do this, go to your main menu and select the Settings que. The select either the Display or Timer options. If you selected the Display option, select Backlight and change the time to your desired setting. If you selected the Timer option, select Auto Power and change this setting to off. If that doesn't solve your issue, reply back and and I'll see what else to do. I hope these options get your music device back up and running. If you have any questions, comments or concerns; reply back to this website. Thank you for taking the time and oppurtunity to read this solution and choose FixYa as you one-stop solution spot to answer all your problems. Thank you and have a good day, afternoon, evening or night; whatever time you are reading this.
Mar 28, 2011 | Jwin MP3 Player
Erasing the memory
You can format it by going into the players menu and going to settings and select memory, then format. It should say internal or external and select internal and it should work. Note that doing this will erase all of the music off your player, so back it up. Hope this helps!
Apr 29, 2009 | SanDisk Sansa Fuze MP3 Player
Erasing the memory from my sansa mp3 player
Apr 29, 2009 | Audio Players & Recorders
My LG KF700 wont let me send picture messages or play music
You have to move all the stuff from internal memory onto external memory and this will then work for you. And should no longer say it is full. Follow >>
menu> my stuff> sounds OR images> click the sound OR images you want to move over by clicking option> file> move to external
Apr 05, 2009 | LG KF600 3MP InteractPad Triband Phone...
LG shine KE970 MP3 player wont play music from memory card
yes you can, just put the mp3 file on folder "Sound" on the external memory, it will be automaticly put  in your playlist mp3 player.
Feb 23, 2009 | LG Shine KE970 Cellular Phone
EnV2 does not recognize MP3 files on micro SD card
This was tricky, but I was able to get MP3 files recognized on my daugter's phone.
First, the MicroSD card needs to be formatted by the phone. The phone requres a special directory structure to be created. You may be able to do this manually, but I did it by letting the phone initialize the card. To do this, insert the MicroSD card. Make sure you push it all the way in.
Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 3 Card Memory. The phone should recognize the card and initialize it by creating the special directories for My Music, My Videos, My Sounds, etc.
Then put the card into your PC and copy your MP3 files to the My Music directory on the card. I could not get the phone to recognize sub folders, so make sure you copy everything directly to the My Music directory and not the one under it.
Now the card is ready, you have to tell the phone to use your card memory and not its internal memory for these items. Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 1 Save Options. Pick Pictures, Video, and Sounds and set the phone to use Card memory for each.
Now you can import the music into the music player on the phone. Go to menu 5 Media Center. Menu 1 Music & tones. Menu 4 My Music. The music player should then Import yhour music into the player and it should now be playable.
(I think these accurately reflect what I did)
You can also go to 9 Settings, 9 Memory, 3 Card Memory, 4 My Music to view your music.
Jan 01, 2009 | Cell Phones
External memory
perform a firmware upgrade to
restore it.
– Please go to http://www.rcaaudiovideo.com/faq
for more details.
This will also get you to the manual
-Tha Mp3 Doctor
Aug 06, 2008 | RCA TH1101 MP3 Player
Lg prada
Unfortunately, there is no way to do this. Only in camera/video mode you can set the default memory to the card. Everywhere else, the internal memory is default.
May 18, 2008 | LG Prada KE850 Cellular Phone
Corrupted MP3 need to Reset?
k, to erase internal memory do this:
1-Turn off device.
2-Hold power to start but keep it held + the menu button, hold those UNTIL the menu comes up.
3-let go of the switch and button and scroll to 'erase internal memory.
This helped me alot .
May 01, 2008 | Insignia Pilot MP3 Player
LG Prada Phone and how to download mp3 onto it
I have posted information in 'hints and tips' regarding media files (pictures mp3s etc).  The first thing to remember when sending files to your phone is that they have to be done one at a time as the phone memory is limited.  The phone has a memory card inside it which is extra/external to the phone memory.  What is confusing is that you cannot send files directly to this memory card so each file you send to the phone has to be moved to the 'external memory' before you send another to the phone.
Jan 30, 2008 | LG Prada KE850 Cellular Phone
RCA Pearl TH1102 MP3 Player Logo
105 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
