I have a Toshiba Satellite C655. The screen is malfunctioning as you can see. The screen has 3 vertical striped lines which has divided the screen into separate parts. The cursor will not pass through
  • 2 more comments
  • Brandi B
    Brandi B Nov 05, 2012
    Does the monitor flash or change when you open and close it?
  • andrew wakefield Nov 12, 2012
    No the picture quality is pretty much the same. No flashing or anything.
    I don't know which laptop model is mine. I doubt I still have the box and the website has various versions of a Satellite C655. So I don't really know what to do. Also, the lines will go away if I continuously restart my laptop. It's just annoying that I have to restart it up to 5 times for it to run normally. I don't know if that changes anything. But the lines will sometimes come back after my computer has been shut down or goes to sleep for a while.
  • Brandi B
    Brandi B Dec 26, 2012
    That is crazy. I would start off by buying a new lcd replacement screen and installing it. It is a matter of unscrewing some screws and just being careful when it comes to the Laptop LCD lamp backlight lamps that illuminate the back. Most lcd screens will be sold with them already in place.
Had this problem once and a found out how to fix it. It's a hardware prob, to fix this prob your Pc has to be on while doing it, this way you can see if the problem has been fixed or not. You need to unscrew all screws on the shell of the screen. Then you remove the two screws found at the bottom of the screen they are found close to the hinge.
Now the back part of the shell should be off. once that is off just disconnect the silver cable that is connected to the screen and reconnect it again and bend and squeeze it to see if it is a shortage in the wire. If not remove it once more and reconnect it again. (should be fixed now)
Use a strip of tape to hold it in place and your done. use it for a couple hours to ensure it fully functional then put it back together and you're done.
Posted on Jul 20, 2013
Posted on Jan 02, 2013
    Problem Solver:
  • 10 Answers
Try updating the video driver on the laptop. The issue could be software related.
Click on the following link to go to Toshiba's downloads page. Select your laptop model and then download the newest video driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Posted on Nov 05, 2012
  • 1 more comment
  • alijan Jan 02, 2013
    please tell me
ebarrick
  • 38 Answers
SOURCE: laptop screen has vertical black and white stripes
when you hook up the external monitor did you hit the fn key and f5 this should turn on the external monitor port
Posted on Apr 12, 2009
micromend
  • 748 Answers
SOURCE: Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
Posted on Mar 22, 2009
  • 846 Answers
SOURCE: Vertical lines in my laptop screen
if the lines flicker and change when you put pressure on the screen it sounds defective lcd screen, there are these conductive rubber pieces that lead the signal into the lcd panel and once the connection deteriorates there is no going back. the screen could still be replaced, there are laptop repair places that do it, but you have to have to weigh your options with buying a new laptop, repair could be up to 50% of what your's is worth as a 2nd hand laptop.
you can try to fix it yourself, there are guides online on google and you usually get the screen on ebay for around 150.
Posted on Jun 18, 2009
  • 82 Answers
SOURCE: my laptop has its screen divided into 8 parts, 6
You have display problem comes from impact or presure to top of the laptop. That is moves the connection flex cable from LCD and board.
Another small problems is also small chips on screen that can not be possible to fixed. ( cracks on METAL LINEs IN GLASS) causes the problem.Another issue is LCD cable might faulty that need to be change.
Show techGuy see what they will tell you.
Goodluck
JMC
Posted on Aug 12, 2009
I have the same problem too.
Its like my laptop has had a stroke. Not only do I have the coloured lines issue but I also have a stripe that is about 5inches wide (Everything in it is darker on half the screen).
I thought i'd put this comment here just in case anyone got in touch with Toshiba. copy and paste this entire thread to show them that THIS IS A COMMON PROBLEM.
Not that they would care any way- Toshiba don't build things to last any more. My sister has had two Toshibas break just after the warrantys have expired. I have two friends with the same Equium A60 laptop as me and all overheat and turn off.
Come on Toshiba, sort it out. Every customer you get, is a customer that will not be returning and probably put off for life. I know I will never be buying from you again.
Is that the kind of service that you want to be giving?
"At Toshiba quality and reliability is at the heart of everything we do. With technologies being developed in more than 30 separate R&D laboratories and over 300 subsidiary companies around the world Toshiba engineers are dedicated to finding the best product solutions for you, the customer."
Why don't your products last then???????
Instead of rushing to get your products out and spending a fortune on advertising, spend more time and money on PRODUCT TESTING . You'll see that word of mouth, satisfied and possibly even (dare I say it) happy customers will get you a lot more sales and respect than any advertising campaign can do.
Hope to see some improvements soon and I pity anyone that is struggling with their Toshiba.
Best Regards
Murdoch Oxley
Product Designer
Posted on Nov 17, 2009
Vertical lines on screen
Desktopsbyduck-Computers 225-290-5733
682 Wildcat Creek Rd, Ellijay, GA, 23455..I believe after update to newest video driver you still have the problem call about a possible screen replacement:
Apr 17, 2014 | Toshiba Satellite C655-S5540 Laptop...
Did you damage your screen (i.e. step on it, wet it, ect.)? If you did then you might have to take it in for repair. Regardless, you might just need to call a troubleshooting or help line/number, for that particular brand ( i.e. dell, toshiba,ect.)
Jan 02, 2013 | Computers & Internet
Connecting charger and letting charge for sometime...charging light doesnt turn on and laptop doesnt turn on...any advise?
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-65w.html
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-3-95a.html
Nov 07, 2012 | Toshiba Satellite C655-s5140 Laptop
Toshiba Satellite C655-S5125
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
11th heading down - Satellite A10. (A10 in Blue)
Go down to the second line, (Begins with A350D in blue), and click on -
C650. (You can also click on C655D )
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
Now what is the problem? Post in a Comment.
Apr 21, 2012 | Toshiba Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
Feb 16, 2011 | Toshiba (P000257700) Microphone
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
722 people viewed this question
David Payne
David Payne
