Question about Indesit W 123 Front Load Washer
Irregular banging during cycle
(Not sure machine is W 123 but is an Indesit front-loader only a few years old) During its cycle and spin, there's a sporadic banging coming from within the tub. It sounds like something loose between the inner metal and outer plastic casing. It's a metallic irregular banging and it may be the bearings. When the machine is off I can manually spin the tub; the banging still occurs even then. Anyone know how to even get to it, and hopefully replace it? Thanks in advance.
  • David Zoidberg May 22, 2007
    Thanks tresilla, I may not attempt fixing it if I'm likely to make it worse (or not the right tools), but I did remove to back: Whilst twisting the tub from the back (and from inside)it seems to spin smoothly, but then punctuated with lighter/heavier metallic knocking. It's not a whirring sound nor rattling, but like a resonant thud. The bolt, I've seen is, from the back, in the center of the tub. Should I unscrew this? Where is the heater? Sorry for all the questions, but I'm inexperienced and not at home and can't view it right now to check. Again, thanks for your time and attention.
    President:
  • 1,462 Answers
These washers are a swine to dis-assemble and i would not recommend it unless you are experienced. on most indesit, the bearings are in a spider bolted to the outside of the tub. take the back off and see if you can localise the noise to the bearings worthwhile also taking the heater out (one nut in the middle), peer in and check no foreign object causing the noise
Posted on May 22, 2007
Just had my machine to bits last night ( wa105) what a job to disassamble found that the spider had broken off the 3 legs drum also cut a hole thru water caseing total right off ordered new washer-cant grumble though lasted 7 year with out a problem -cant get that model any more maybe down to this bad spider problem shame though got complete parts for this model apart from drum etc- Richie
Posted on Feb 17, 2010
I had a similar problem to find that the spider supporting the drum was cracked in two places
Posted on Jun 22, 2007
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
437 people viewed this question
Top Indesit Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
