Question about SimpleTech 120GB SIMPLEDRIVE PORTABLE USB 2.0 DESIGNED BY PININFARINA 120 GB Hard Drive
Simpletech external hard drive not workin on windows 7
My external hard drive is powering up and when plugged in my windows 7 laptop recognizes that it's there, installs drivers, then nothing for a long time. At one try got a "bad parameters" warning on the drive. I've tested it on my new netbook as well and it does the same thing
  • Radha Nov 05, 2012
    The drive works fine on any system that is not windows 7. The simpletech website is now called something else and has no support for this drive. Any ideas?
  • SimpleTech Master
  • 27,725 Answers
Windows 7 seems to have a lot of issues with external hard drives and any usb attached devices
Click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
the next works on usb data / pen drives im not sure on external hard drives
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
and i have found that leaving the a usb data drive plugged in and restarting my computer W7 my usb drive will work again (strange)
whatever works
hope it helps
Posted on Nov 06, 2012
5 Suggested Answers
Randy V
  • 236 Answers
SOURCE: SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Posted on Aug 12, 2008
  • 49 Answers
SOURCE: Hi - I have a simpletech USB external hard drive
Hi sir, Fewer Portable HDD's wont support Front side USB port so choose different USB port sure it wil work i prefer BACKSIDE of your system :)
Posted on Jan 15, 2011
bronk50
  • 27725 Answers
SOURCE: Solve Your SimpleTech (SP-U25/120G) 120
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Posted on Jul 04, 2011
  • 10406 Answers
SOURCE: I had backed up my
Does the external drive work correctly when connected to any other computer?
If not, then it has "died".
It might be possible to open the SimpleDrive case, extract the disk-drive,
and connect it as a "slave" disk-drive in some computer, to see if the "bare" disk-drive can be read.
Posted on Aug 19, 2011
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
I've switched my SmartTech drive from an XP notebook to a Windows 8 notebook (new device) but it is not recognized as a drive. Power light is on and the USB port is functioning fine. Any suggestions on how...
This is a common failing when connecting XP to windows from 7 on. It is possible that the external drive, built in hard drive controller has been killed by your laptop(or just failed with age) Try it in a computer with an older operating system to see if the drive itself is at fault.
Sep 18, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
I just got a new laptop and I no longer have my softward installation disk for my simpletech 320GB external hard drive. I've gone onto simpletech.com and am having trouble finding the software program. ...
If you have a new laptop, you should not need the install disk to see the drive as the drive is USB 2.0 compliant.
And no, nothing will get erased unless you erase it on purpose.
Plug the drive into you laptop (USB cable).
Plug power into to the external drive.
Turn the drive on.
It may take a minute or so but your laptop should recognize the drive. It will get assigned a drive letter (assuming you are using Windows).
Apr 19, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Cannot get computer to recognize my simpletech external hard drive. I have windows 7
A problem I commonly have is if the external drive is plugged in to a non powered usb hub the unit does not have enough power and will not be recognised, ensure it is plugged directly into the pc tower or if you have a laptop try an alternate usb port as some may not be powered.
Mar 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
New computer doesn't recognize device
uninstall the drivers for the hard drive then reboot install drivers that came with drive and then plug it in.
Mar 27, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
My drive is not recognized
I've had this problem before.
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Jun 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Transfering data
If you are having issues accessing the drive i've encountered that situation before
Try This:
  5. Turn on computer
Mar 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 120GB SIMPLEDRIVE PORTABLE USB 2.0 DESIGNED BY PININFARINA 120 GB Hard Drive Logo
213 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
