Question about Polaroid 3211TLXB 32 in. LCD Television
I have a 32" Polaroid LCD t.v. For a couple of days the screen flickered when I turned it on. Now, it powers on with sound, but no picture. The t.v. is about 2 years old. the tv powers on and i have sound but no picture.
  • Anonymous Jan 05, 2009
    i got this tv about 2 years ago i get sound but no pic first i was able to get a pic after unplug power cord for a couple of times, now is completly dead no pic
  • 88 Answers
Need to check video driver& power supply. maybe loose solder.goodluck!
Posted on Jan 05, 2009
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
32" polaroid hdtv turn on but there is no picture,
You have a bad capacitor or two in the lighting of your LCD screen. I have not worked on this particular unit. I have had a smaller version of this TV. On the smaller version there were two capacitors in the power supply. The transformer that lights the LCD panel ,yes, is in the power supply.There were two of them and I think the values were 35 volts at 1000Mfs. I hope this will clue you into a fix. Yes, I really think you have a couple of bad capacitors. If you pull this TV apart, by all means inspect all the capacitors in the signal board (has the RF connections and all your RCA connections). You will find several bad capacitors by now. I do repair TVs, so this is good advice for repair. Thanks for asking and show all hands of support!l
Jun 15, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
No picture but there is sound
think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Feb 10, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
The Polaroid Flat Screen TV just died.
Sounds like a bad capacitor on the power circuit board. best place to look
Mar 30, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
No picture, good audio. Replaced motherboard...
Feb 12, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Polaroid 3211TLXB 32 in. LCD Television Logo
150 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
