Question about Uniden TRUNKTRACKER III
TRUNK TRACKER 3
I SEEM TO HAVE A PAUSE AFTER SO MANY SECS. I THINK CLOSE CALL AND PRIORITY IS OFF BUT NOT REALLY SURE
  • Anonymous Jan 06, 2009
    I BOUGHT MY SCANNER FROM A PAWN SHOP ,NO DISC OR ANYTHING,I DO HAVE A PC CABLE WITH IT,SO HOW CAN I CLEAN IT UP? I ALSO NEED TO KNOW HOW TO PROGRAM SHREVEPORT POLICE IN IT ALSO...CAN YOU PLEASE HELP ME?/ T/Y CHAD
  • 490 Answers
Is your disk full? If there is no space for the scanned data to be written, then you will notice a pause. Clean up the disk or store in alternative location.
S. Mohan
Posted on Jan 05, 2009
It seems that my 2005 Lexus ES330 trunk light won't turn off. How to check whether the trunk light is off when the trunk lid is close?
Remove the bulb if you think it runs the battery down. the switch is part of the latch assembly of the trunk.
Jul 07, 2012 | Cars & Trucks
While listening to my scanner every so often, does not seems to be a specific interval, maybe 3 or 4 seconds usually, I get a silent pause missing conversation. For instance the ambulance dispatcher might...
sounds like you have another channel set for priority and it is scanning back to check that channel. In the manual mode scroll thru channel's until you find one set with a "p" or "pri" on the screen. Hit the priority button and this should resolve the problem.
Sep 09, 2011 | Uniden SC230 Handheld Scanner
I have a 2005 Toyota Corolla XRS. It has an Alpine SEC-100s or SEC-150R security system. I'm not sure which it is, this is what is on the front of the owner's manual. I need to know how to disarm...
Locate the device that is attached to the trunk to detect opening and move it away from the door so that it is not activated. Or if it is a normally closed switch then just jump the wire going to it so it is always closed.
Aug 26, 2017 | 2005 Toyota Corolla
2010 Town Car, trunk wont close...I think i accidentally pulled on that emergency pull inside the trunk ( not sure if that's the reason) but now i tried pressing the button on the door, tried using the...
ok the latch that holds the trunk closed might be engaged u will have to take a screw driver and press it to release it not the latch on the top the one next to the bumper look closely at the in side of it.
May 11, 2011 | Lincoln Town Car Cars & Trucks
Vw 2006 passat trunk won't close
this always happens to my 06 passat when its really cold, im talking 0 or lower. i try not to open the trunk in the winter if i can help it. Its annoying but in the summer i have no problems. I have herd of alot of other people having this problem, VW knows about it and dosnt think its a recall item for somereason, look for your fancy gas door to not open next, i know of 3 people that started having trunk problems and then the fuel door stopped working, not sure if it has anything to do with it or not. but It happend to me and now i have the auto fuel door disconnected from the inside of the trunk.
The trunk issue isnt anything big to worry about it seems intermittent. I found latches and there a little pricey thats why i just deal with it.
Nov 08, 2010 | 2008 Volkswagen Passat Sedan
Audio cuts out for a sec.every 3 sec when onscan
It sounds like you have the scanner set for PRIORITY scan and the cut out you hear is the scanner sampling the designated PRIORITY channel. You can easily confirm this just by checking the scanner's display and noting if PRI is constantly displayed. To turn off this feature, just press the FUNC and PRI keys while in scan mode.
Bill B
Listening in since the 60's
Oct 05, 2010 | Uniden BC72XLT Handheld Scanner
Trunk catch no longer seems to work on Park Avenue
Check your fuses. It could be something really silly like that.
Even if it has been meticulously maintained, this is, after all, a 16 year old car. The more neat gadgets you have, the more can go wrong. If all the fuses are ok, start checking the relays. A Haynes manual should help you track down the correct one.
If the relay is ok, then your next stop is the solenoid.
May 17, 2009 | 1993 Buick Park Avenue
Boot open
Hi
The car thinks the the trunk lid lock is open !
Hope this is of help !
Good Luck !
A FixYa rating would be ever so nice...Thank´s ....John.
Feb 27, 2009 | 2002 Jaguar X-Type
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
'stuttering' reception
usually the close call, weather priority, or channel priority settings are on...or just one of them.
Jun 19, 2007 | Uniden BC246T Handheld Scanner
398 people viewed this question
Top Uniden Office Equipment & Supplies Experts
danielle yancer
danielle yancer
Lawrence Oravetz
Are you an Uniden Office Equipment and Supply Expert? Answer questions, earn points and help others
