Question about Freezers
Freezer not freezing
The freezer side is only freezing at the bottom and the fridge side is doing the same thing, what is causing this?
    Top Expert:
  • Freezers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
  • 13 Answers
SOURCE: Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Posted on Jan 21, 2009
bobicehouse
  • 1524 Answers
SOURCE: replacing a heating element in the bottom of a fridge freezer
Look at the old heater. There should be clips holding it to the evaporator coil. Also follow the wires and disconnect them. You may want to unplug the unit first.
Posted on May 18, 2009
mgprice
  • 744 Answers
SOURCE: water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Aug 31, 2009
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
Fridge/freezer won't cool completely or freeze
Things to look for and fix yourself woulf be to clean the coils on the bottom and check the fan motor on bottom, make sure it is ok, Look on back of the freezer walls for frost buildup, a sign the defrost heater is dead.
May 09, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Francois
Aug 01, 2008 | Whirlpool Freezers
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Freezers Logo
139 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
