Question about HP vp6320 Multimedia Projector
HDCP compatible I hooked up my DVI input on my HP VP6320 projector using an adapter that has an HDMI connector. I connected the HDMI end to my DVD player and it played for about 10 seconds then I got a message" HDCP not compliant". Am I missing an adjustment to a setting somewhere?
  • dodgyboy Mar 09, 2009
    When i connect my
    DVI input on my HP VP6320 projector using an adapter that has an HDMI connector. I connected the HDMI end to my SkyHD set top box, it plays for about 10 seconds then the picture refreshes itself putting the main menu index on the projector screen up before going back to the picture from SkyHD, is there a setting im not using? any help would be greatly appreciated
    Problem Solver:
  • 18 Answers
There is no fix to this. basically HP did not make the HDCP very robust. It will DHCP with some DVD players, not all. HP is calling this a computer projector and down play the issue. No fix, try different DVD players. I had good luck with Toshiba HD.
Posted on Jun 06, 2009
Nec MT1060 blue screen when connected to a Hdmi source thru dvi port.Dvi setting to match Hdmi resolution.tried different cables and dvi to Hdmi adapters....any ideas..??
Hi Genaro,
Sounds like an issue with the HDMI HDCP content protection. I do not think it will be possible to connect using a DVI to HDMI cable.
Jan 19, 2014 | NEC MT1060 Multimedia Projector
Playing blue ray movies on jvc dla sx21 projector
It should work right away. Try again, restart the projector and ps3 make sure everything is connected and the input on the projector is on dvi.
May 17, 2008 | JVC DLA-SX21U Multimedia Projector
Which cords and/or plugs should I use inorder to connect a projector to a computer
if your desktop doesn't have a standard vga socket then you can get a dvi adapter that fits onto the end of a vga lead. you will still need a seperate cable for audio as a dvi connection only does video.
Aug 02, 2012 | Computers & Internet
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
I'm tryingto hook up my lp350 to hdmi. I purchased an m1-da to hdmi adapter. When I hook up my dvd player or PS3, I get a message that the display does not contain HDCP compatibility.
Unfortunatly your projector is not HDCP compliant. In other words it lacks the proper hardware and software which is neccessary for you to watch HDCP content. HDCP is a form of copy protection.
Dec 30, 2009 | InFocus LP350 Multimedia Projector
DVI-HDMI not working with Sanyo Z2
HD comes as 720p and 1080p - the Sanyo will cope with 720 but not 1080 full HD - check the specs in the manual. You should have a DVD output setting for screen mode.
Sep 07, 2009 | Sanyo PLV-Z2 Multimedia Projector
I would like to connect my Sanyo PLV-Z2 project to a DVD player with HDMI output in order to higer quality. I used a HDMI->DVI cable and connected DVI to Z2. I set the input 2 as RGB-HDCP. However it does...
I have the same unit (2 of them actually.) I have spent a lot of time on this very issue. The problem is that although the unit is "supposed" to be HDCP (digital copy protection) compatible, it is not fully. I've found that with some DVD players it will work for a minute or two and then go black, and with others, it will flash on and off, and with some it will never do anything but black. I have only found 2 ways around this. 1 is to use a computer (which does not use the HDCP) windows Vista/windows7 might have the same problems, but XP/2000/Linux work perfectly. The other solution that worked was to use a Playstation3 which seems to work perfectly with it playing DVDs and BlueRays.
Feb 23, 2009 | Sanyo PLV-Z2 Multimedia Projector
Dvi input for watching tv
the DVI input must be HDCP compatible in order for HDMI to work. It's a DRM encryption protocol. Condolences. Blame hollywood for it. The monitor model is too old to have had HDCP support built in to the DVI input.
Jul 30, 2008 | Dell W3000 30 in. HD-Ready LCD Television
LP 640 projector not able to display 1080p
Hello, The LP640 will NOT down-convert 1080p
1080i is the max it can down-convert.
As far as the DIGI input, it is not DVI... It's a proprietary
InFocus format they call M1-D P&D and is NOT HDCP compatible. I have several LP640 manuals, some quite old and none of them claim that 1080p is a valid resolution. interesting that your manual says it is... very odd indeed.
Good Luck!
Cheers
Dec 15, 2007 | Optoma Projector Multimedia Projector
HP vp6320 Multimedia Projector Logo
375 people viewed this question
Seeker5211
Seeker5211
