Question about Car Audio & Video
I have an aiwa cdc-x927-myuc. it received a voltage spike of over 12v. i had a guy check it out and he said the preamp burned out and couldn't be fixed. can it?
informatica
  • 1114 Answers
SOURCE: Aiwa CDC-X304
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=418
Posted on Aug 06, 2007
imseth85
  • 30 Answers
SOURCE: aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Posted on Mar 31, 2008
tech48
  • 624 Answers
SOURCE: aiwa CDC-X517M Car CD Receiver . . .
The part you are looking for is called the "wiring harness" or sometimes called the "dc cord"
The best way to buy this (and you do need it to use the radio) is to find a local repair center that repairs aiwa car stereos. Ask them if they can order the wiring harness for an Aiwa CDC-X517M. I don't know what Aiwa charges for them, but it should not cost more than about $30 or $40. Some are cheaper and some are a little more.
I did a search for it on google and could not find anything. Very unusual.
The four spots you refer to are the RCA jacks to connect to an external amplifier. 2 are red and 2 are white.
That thing that plugs in above the 15 amp fuse is for your wiring harness.
The circular thing is a din cable jack and that is used for an external CD changer.
Once you get the wiring harness you should take it and the radio to a place that does car stereo installations and they can do the rest for you.
I hope this helps you out, and if it does I would really appreciate a good rating. Most people we help here never rate your help :( and we do most of this for free hoping for a good rating as a thank you for the help :).
Hope you have a great day,
Dave
Posted on Jun 20, 2008
SOURCE: Aiwa CDC-X207
hi yellow go in left bottom corner
Posted on Aug 17, 2008
SOURCE: Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Posted on Feb 15, 2009
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Need a faceplate for aiwa CDC-X304. Where can I get one?
ok I have the face your looking for? CDC-X304 face
May 21, 2012 | Aiwa CDC-X304 CD Player
Aiwa cdc-x317 will not eject cd. How to eject cd from Aiwa cdc-x317?
Somewhere on the front of deck there should be a small pinhole just big enough to fit the tip of a pen push it in either pen or Sharp object. It should force it out.
Sep 11, 2011 | Aiwa CDC-X317 CD Player
I just got the aiwa cdc-x227 and the mute is on.how do you unmute it?
check for a logo that shows a speaker with a cross(X) across. just switch this back. this is also available on the remote. You could normally find this on the top side so as to mute easily when in a traffic junction. Check if this button is jammed. Also check if the display shows a mute , if not the sound reduction could be a different issue related to the audio output. check if any speaker connections are short, or speakers connections touching the body. Chek on the wiring once again with a multimeter , for any shorting, correct positve voltage and good ground. hope this helps. Good day
Jul 07, 2010 | Aiwa CDC-X227 CD Player
No sound from my car stereo, a aiwa cdc-z137.
Doudle check rca's. Also check the setting in the menu browers. Make sure the mute overide is not on. Not sure if your model has it but is very common, and overlooked
May 13, 2009 | Aiwa CDC-Z137 CD Player
Aiwa CDC-X207
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Aiwa CDC-X304
Aug 06, 2007 | Aiwa CDC-X204 CD Player
Help
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Jul 07, 2007 | Aiwa CDC-X217R CD Player
AIWA CDC-X115
Check BOTH of your power connections and your ground too. Make sure you actually have 12v at each connection and don't have a blown fuse etc. If you are lucky then you will solve the problem. Good luck.
Apr 29, 2007 | Aiwa CDC-X115
Car Audio & Video Logo
167 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
