Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
I want to use router as wireless extender - NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
  • NetGear Master
  • 32,281 Answers
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers. http://www.fixya.com/support/r8279884-setting_router_as_repeater
Posted on Nov 06, 2012
I want to hardwire a range extender to my wireless router.
You could use wireless routers as an extender if you don't mind the hassel of configuring it.
Dec 15, 2013 | Computers & Internet
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Mar 12, 2011 | Belkin N1 Vision Wireless Router
I have about 300 meters distance and I would like to connect my internet connection to the end. I'm using smart bro connection, is it possible using router to spread signal of internet on wireless with...
Wireless-g router can only extend it's wireless signal up to 50 to 75 feet. You can use a wireless signal extender to be able to extend the signal further. And yes, you may have password on the wireless network.
Jun 07, 2010 | Linksys Wireless-G WRT54G Router
Range Extender DWL-G710 & Wireless N Router DIR-615
Try to configure your new router and you have to reconfigure the Range extender to tally with the new router. The IP Address that the range extender should have should depend on the DHCP server of your router that provides the IP Address.
Jan 12, 2010 | D-Link AirPlus G DWL-G710 Wireless Range...
Extend Range ?
The best way to extend a wireless signal is to get a wireless range expander/extender , because a high gain antenna really give the needed boost of wireless signal.....
Don't forget to rate the solution FIXYA thank you............
Oct 16, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Connecting 2 wireless routers
As a wi-fi technician, it is not recommended to extend the wireless signal using another wireless router. Having 2 wireless routers will just cause conflict to your wireless network. If you still have time, please replace the router with a Wireless Access Point (WAP54G). WAP is easy to setup. Just plug it to one of the ethernet port on the back of your router and run the setup CD that came with it, that's it. It'll extend your signal.
If your main concern is just extending your wireless signal to another far place outside your house, Wireless Range Expander (WRE54G) can also be used. It is a similar device like an Access Point but its signal extending capability is more powerful than Access Point. Its also easy to setup, just the setup CD that came with it.
You can also contact the Linksys toll free tech support # at 1800-3267114 if you wanna resolve the issue over the phone. Hope that helps.
-Regards
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Belkin Universal Wireless Extender Set-Up Problems
Have you tried restarting and resetting the router as well ?
Feb 06, 2008 | Belkin (F5D7231-4) Wireless Router
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
243 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
