Question about LG LFC25760 French Door Refrigerator
Fan not running; ice maker takes days to make ice. Refrigerator is cooling.
    Problem Solver:
  • 21 Answers
Having two motors? if so un of it lost ref. agent..keep distance from wall, for ventilations
Posted on Nov 05, 2012
4 Suggested Answers
SOURCE: Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Posted on Jan 03, 2008
  • 163 Answers
SOURCE: Side by side refrigerator - LSC 27950SW - looking
most likely water is running out the corner of your ice maker and into auger bucket and freezing not allowing it to dispense.check bucket to see if sheet of ice is forming.
Posted on Mar 06, 2009
  • 5370 Answers
SOURCE: i have a lg bottom
The LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message. As the name suggests, this error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue.--------------------
The error "IF or FF" Both this error code are related to fan in the freezer section.
The error code is the freezer fan motor error. It could be a problem with your freezer fan motor or an issue with the control board not sending proper power to the board. Make sure there is no ice restricting the fan motor from turning. If there is ice then check the icemaker fill tube and make sure its in place properly and not leaking down on the evap fan blade. If the fan is not running, then its fan motor problem.Get the motor voltage checked.If its short, the motor has to be replaced.This will solve the problem. To order this fan motor. Click the link below:--- http://www.repairclinic.com/PartDetail/Damper-Fan-Motor-Assembly/1268059 --------------- This should help.Thanks.Helpmech.
Posted on Apr 12, 2011
Admiral Maytag side by side model LSD2615HEW not getting cold. Fan runs. Clicks from the back every few minutes or so.
Its issue with compressor or the problem with defrost timer.It clicking to set the defrost cycle,but not actually working.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Admiral 26 cu. ft. Side-By-Side...
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
Beko fan noisey
It can be worn out or dusty fan motor, or its time to replace fan motor.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Fan turns off in refrigerator section.
Its issue with defrost timer causing the fan to turn OFF.
Get the timer checked.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Freezer fan not running
It can be faulty fan motor or blown compressor capacitor.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
These will help.
Thanks,.
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Why does the unit gurgle very loudly throughout the day?
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Fan has failed on out side unit, It may also need new capacitors.
Its available at sears parts store.
The fan motor may be for $50 and capacitor for $10 to 15
These will help.
Thanks,.
LG LFC25760 French Door Refrigerator Logo
51 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
