Setting up a username and password on my router
  • 32,281 Answers
For me to assist you please supply the make and model of your wireless router.
Posted on Nov 06, 2012
peglegcards
  • 89 Answers
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Posted on Mar 27, 2008
ginko
  • 19396 Answers
SOURCE: netgear dg384g v4
First check that you do not have capitals lock in.Then try again the following whilst you put http://192.168.0.1. on your browser.
Default: 'username: admin password: password".
or
'username: admin password: 1234".
or
'username: admin password: 'blank empty space here'".
If all the above does not work then your router had been used, and password changed, or is fault. in this case bring it back and ask replacement.
There is also a reset button at the back of router. It is a tiny hole where you stick a pencil on router startup to get reset. But if the router is new and does not get default user/password I suggest changing it, It is possibly a return, and you do not know if you get more troubles after reset.
regards
Posted on Mar 29, 2008
  • 5 Answers
SOURCE: Need Username and password to setup
got to http://purelypc.blogspot.com/2008/04/forgotten-router-password.html
for default login and password.......
http://purelypc.blogspot.com/2008/04/default-logins-and-passwords-for.html
it might help u.
Posted on May 06, 2008
  • 84 Answers
SOURCE: Don't know the username to "http://192.168.0.1" router Level One.
If you have never changed this from default then the user name will be "admin" & the password will be "password" or "admin. If you google the default password for Your router model then that shoud find it if this does not work. Don't forget to rate me if this works for you.
Posted on Jul 06, 2009
mail2pvs
  • 390 Answers
SOURCE: When I enter "http://192.168.0.1" it's asking me username and pas
hi
for the username use administrator and ofcourse the password that u have set
cheers
pls rate if it was any help
Posted on Jul 07, 2009
I need to set a password for my Linksys Wireless-G WRT54G Router, but the websited 192.168.0.1 to set the password isnt working. I need help ASAP. Thank-You
to access the router page for linksys, you need to type 192.168.1.1 on the address bar. username is " admin " password is " password " if it doesnt work, try "admin" for username and "admin" for password. then it would take you to the router page. and you can start configuring.
Sep 09, 2011 | Linksys Wireless-G WRT54G Router
Username and password for dlink Im trying to set
If you are trying to access the router itself via it's IP address (192.168.X.1) where X is usually 0, 1 or 2...
The username and password should both be admin
if not, try no username with admin as the password, or try admin as the username with no password.
Jul 11, 2011 | D-Link DIR-300 Wireless Router
Netgear will not accept my password
Well, there are two possibilities: 1) You don't remember your password correctly 2) Some electronic failure messed up your password settings I recommend you to reset your router and reconfigure it, first turn off your router then reset your router by using a small pin or tooth pick and putting it in a small hole in the back of the router push just a little the reset button hiding in the hole for about 5 seconds and turn your router back on, the use default username and password to log into the router config, set up a new password and you're done. Have a nice day :)
Mar 30, 2011 | Computers & Internet
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
How to find out user name ad password
You can reset your router to its default setting by holding down the Reset button on the back of the router for 30sec. After you do that, everything will be back to default settings, including your username and password. Default Username is admin and Defualt Password is password. If you never put a username and password on your router then these are your current username and password so give em a shot without restting it if you want. Hope this helps!
Dec 14, 2010 | NetGear WNR2000 Wireless Router
I tried going through the set-up function on my wireless router and as I was completing it asked for a username and set-up (similar to when initially setting the router up where you enter 'admin' for both...
Step 1:
Access the router's web-based setup page. To learn how, click here. NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click on the Administration tab.
Step 3:
Enter the new password in the Password field and Re-enter to confirm.
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Blitzz wifi router default userID and password?
The default is admin and admin...
If that doesn't work, the reset button will clear the stored login information and reset your router to factory default.
Make sure you hold that button for about 15-20 seconds before you release it. After you did this, you can access your router again via the default IP address2.gif of 192.168.1.1
The default username and password for your Blitzz router are both "admin".
Don't forget that all your personal settings will be erased as well (wireless security2.gif, port forwarding etc.
Nov 08, 2009 | Blitzz Technology (BWA611) Router
Jul 06, 2009 | Levelone CP Technologies LevelOne FBR-4000...
Locked out of wireless router .
On the rear of the router is a recessed reset button. You'll need something like a pen point or a straightened paperclip to press it. Turn off the router (pull out the AC adapter plug), the plug it back in while pressing the reset button. After the lights on the router quit blinking, let go of the button. This will reset the router to factory settings. When you go to //192.168.1.1 and are prompted for username and password, the username is blank and the password is admin. (It's possible the username may be admin and the password is password. This was in some versions of the router.) Then you can set your router up again the way you want.
May 18, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
