Question about Dryers
Moffat heavey Duty Dryer
I have recently noticed on light coloured clothing, when I take it out of the dryer there are black spots here and there on the clothing.I hope you can help this is quite puzzling to me.
  • 3,463 Answers
Hi and thank you for your request.
Assuming the marks were not there before you put them in the dryer, then there are a couple of possibilities for the marks appearing.
Check that none of the clothes lifters or ribs as they are sometimes called in the drum are not loose, as the clothes could get caught in any gaps,make sure that there is no large gap between the drum front and the front of the dryer, as again clothes could get caught here,,check to see nothing is stuck on the drum itself that could transfer onto the clothes.
Make sure the drum is free to turn and that there is no unusual noise coming from it, if it does appear to be noisier than usual ,then it could be the drum rollers or bearings are starting to wear and this could transfer grease and the like onto your clothes.
Hope these suggestions help with your prob.
Plz feel free to leave any comments and rate my suggestions.
Thanks
Posted on Jan 05, 2009
Black spots and smears on clothes from DRYER (not washing machine
Sounds as if your going for a spin. Not really here is where the problem could be. 1 the bearing on the mchine is going bad. Since the bearing is sealed with its own lubrication the seal has blown seeping the lubrication into the machine one the temp is right to cause the oil to flow. How is this possible you ask? it is possibly flowing down the drum as the drum rotates and entering the dryer from the front of the drum. I would remove the back of the dryer and inspect the area and if all is right with the stars you may not have to take that spin
Good Luck
Dave
Jan 12, 2010 | Fisher and Paykel DEGX2 Dryer
How do you get access to the turning drum of a heavey duty large caapacity dryer. The drum is sqeeling
first thing, check on the rear of the dryer there should be a sleeve bearing in the center of the back panel try some lite lube and see if the squeel stops if so you will need to replace that sleeve bearing
Oct 17, 2009 | Dryers
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Brown marks on my light coloured clothes
I just noticed My Frigidaire doing the same thing. Using a lightly soapy damp cloth, I cleaned the interior, paying particular attention to the small gap between the drum and the housing. I also took apart the lint pre-filter and screen and cleaned them. There was a filmy build up of the same colored substance. I suspect that dryer sheets are leaving a waxy residue that over time is sufficient enough to rub off on lighter colored, primarily synthetic, fabrics.
Jul 11, 2009 | Kenmore Elite HE4 Electric Dryer
Black spots in cloths after drying
Gas or electric dryer?
If gas, I would be suspect the black spots are carbon, which, based on your describing that when you clean the interior of the drum, the spots return, is coming from the burner area.
1) If the above is correct, then call quit using the dryer serviceman immediately before continuing use.
2) If your handy repairing things, you will need to remove power from the unit, and access the combustion chamber from the backside of the appliance for cleaning.
This will be a messy job, as carbon black is messy. It comes from incomplete burning of the gas as it goes into the combustion chamber. This is normally caused by restricted airflow into the combustion chamber, and that cause is difficult to identify without looking at the unit. Best thing is to just clean the unit up real good, removing any lint buildup and carbon that can be found, and confirming that the proper orifice is installed (is this an LP dryer operating on natural gas, or vice versa.). Once cleaned and all repairs made, you will need to operate the dryer with old, clean rags in the drum for several cycles until you are certain any residual carbon has been blown through.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
DRYER CAUSING SPOTS ON CLOTHES
maybe you have high iron content in your water?? if so theres a product called iron out. supposedly it works well. good luck
May 23, 2017 | Kenmore Dryers
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Black soot in dryer
There are several possible causes: a)  exhaust vent is restricted forcing the lint to enter the dryer shell and overheat and/or be picked up by the blower -- you seem to have inspected this b)  check the hot gas inlet to the drum.. on some dryers, lint buildup can occur in tight spots and it will overheat and char c)  ducting is not intact or leaks allowing lint to leak into the dryer shell -- this will occur over time, and all dryers should be taken apart and cleaned out on a regular basis... also, all ducting should be inspected and sealed as needed d)  verify that the inlet vents to the dryer shell are not blocked and allow adequate air flow to the burner assembly -- natural gas normally won't smoke due to incomplete combustion, but..  likewise, verify the room has adequate ventilation particularly if the utility room or closet is very small,  e)  check the drum drive belt, as it gets old, it will release dust and minute pieces which will be picked up by the blower -- replace if needed... f)  verify that the seals on the drum are still good -- replace as needed g)  as 'washer-tech' advised, do a thorough cleaning and inspection... put it back together with all ducting tight and free flowing
Jun 28, 2007 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
