Question about Hotpoint Washing Machines
Cant change door seal on hotpoint first edition hvl 211
Cant get front panel off
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
gittos73
  • 244 Answers
SOURCE: door seal hotpoint 9540
undue the screws oat the back that hold the lid in place make sure washer is unplugged now open the door undue the clip that holds the front part of the door seal on this maybe a spring clip hidden under the edge of the seal or there will be a plastic clip remove and pull the clamp away now looking from the inside through were you have taken the lid off look to the back of your seal there will be a screw clamp un-screw it door seal will now pull out reverse this order to put new seal on m8
Posted on Sep 24, 2007
  • 1462 Answers
SOURCE: Hotpoint Aquarius WF440 Repalce Door Seal
no need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
Posted on Sep 07, 2008
FitzOriginal
  • 842 Answers
SOURCE: Hotpoint Door Seal WMA64
I have reproduced the details of my article: http://www.fixya.com/support/t1543617-door_seal
here. I hope this will give you the information you need.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until it is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Posted on Feb 15, 2009
  • 662 Answers
SOURCE: Change door seal
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
Posted on Jun 08, 2010
I CANT GET FRONT OFF HOTPOINT AQURIUS TI CHANGE RUBBER SEAL
to change the door seal you have to take the front boot ring off fold the door boot into the drum and undo the retaining clip around the door seals inner drum you can get a screwdriver in from the top a bit tricky but its the only way as the front is riveted on and wont come off like the older machines
Dec 08, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
I cant get the back off hotpoint aquarius wma56 to change bearings
the back does not come off but the front does.
remove top lid ( two hex head screws on side of lid, under plastic covers)
take out dispenser drawer. reveils 3 screws
remove screws and slid front panel to the right (reveils 2 scrwes left and right)*
remove bottom kick strip ( reveils 2 more screws)*
undo door seal retainer, and remove 2 screws holding on door lock.
now remove 4 screws holding on front panel.*
panel now lifts up and off.
Jun 25, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
How to change door seal on hotpoint FEW12 washing machine
Mar 28, 2010 | Hotpoint First Edition FEW12 Front Load...
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
Solution for washing machine
  1. remove top cover.
  2. Remove soap dispenser draw.
  3. unscrew the screws securing the the soap dispenser to front console.
  4. Pull timer dial off, noting position of symbols.
  5. slide console panel to right, and lift up out of way of front panel.
  6. Undo 3 screws securing top of front panel.
  7. undo 2 screws securing door interlock to front of panel.
  8. Remove plastic clip securing door seal to front of panel.
  9. remove wire clamp band round front of door seal.
  10. Undo 3 screws at bottom of front panel securing it to cabinet .
  11. remove front panel.
  12. Unscrew thye top wire clamp band securing the seal to drum front.
  13. remove door seal.
  14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
  15. reassemble in reverse order.
  16. Please rate my solution.
  17. Thanks.
Nov 06, 2009 | Washing Machines
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
How do i fit the door seal
hi the door seal is held in place by two large clips wjth screw tightening best access is to remove the top row screws on rear panel these also hold the top panel then lift top panel at rear and pull top backwards and clear of front facia then lift top off ok ? now you have access to the door seals clips which secure seal to front panel and the outer drum loosen screws fully this releases clips enough to gently remove seal clean surfaces of seal to drum and front panel then fit new seal as previouse one resecure clips then re assemble covers hope this helps and clear enough ?
Mar 09, 2009 | Hotpoint BWM12 Front Load Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
I need to change the door seal on a Hotpoint Aquarius WMA50
Basic diy tools should be ok. Take out lid screws behind plastic caps on edge(will be stars but small flat will do it).Lift front of lid and push back to remove.Remove kick plate and take out screws behind it.Remove band holding front end of seal and detach seal from rim of opening. Remove screws holding door lock and push lock through. Remove soap drawer & take out screws behind it.Carefully bring panel forward & slide to right to remove(Take care here with board &wiring)Remove screws holding front panel & lift front panel & remove it.Remove band from seal and your there.Note locating slot on seal. If possible get an extra pair of hands to hold panel with board to avoid damage.
Nov 16, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint first edition
UNPLUG THE APPLIANCE - Hi sorry about the delay - the door needs to lock before anything will work - So - Either the door lock is faulty or the circuitry to the door is faulty.
The door lock is not too difficult to replace. Engineers reach it by going through the front ( where the door seal connects onto the front panel)
The lock connects directly to the Timer/circuit board so if it is not the lock it will be the timer board.
Hope this helps
Mar 16, 2008 | Hotpoint First Edition WMA20 Front Load...
Washing Machines Logo
154 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
