Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ge model pfs22sisbss
Freezer and fridge go above set temp. about 15 deg
  • 109 Answers
SOURCE: GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Posted on Mar 31, 2008
  • 93 Answers
SOURCE: GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Posted on Jul 17, 2008
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
  • 15 Answers
SOURCE: My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
Posted on May 26, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
Ge psh25sgsa - Wont hold temperature
The water is from the heating element that does the autodefrost. There should be a drain for it though.
Dec 16, 2013 | Refrigerators
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
GE Model GSS25JFMWW, started with the ice maker not working, then the water doesn't work half the time. Now the freezer and Fridge both stop working, and out of nowhere the will start again after a couple...
Hi and welcome to FixYa, I am Kelly
The ice-maker not working was a sign that the freezer temps were rising above 14 - 16 deg F. There ice-maker has an internal thermostat that activates the harvest cycle when the temps reach around 15 deg F. If the freezer is warming up it will never make ice.
What is most likely causing the recent symptoms of the unit shutting of and not stating for a long period is either an intermittent defrost thermostat (
The unit has a timed defrost cycle to START the cycle but there is a 60 deg F thermostat that opens to terminate the defrost cycle. If the defrost heater does not work the unit has to slowly warm up toward room temp without heat to reach 60 deg F for the defrost cycle to terminate. This can take a very long time if the freezer is more than 50% full as the contents will keep the temp below 60 deg F for an extended period.
I suspect you have a defrost element failure. Item 230 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210406&diagram_id=22357329#d22357329
You should read resistance across the defrost heating element. No resistance = open element.
There is the very very remote possibility that there is a problem with the main board. Item 801 this link:
Since the unit works once defrosted I doubt the main board has failed.
There is a thermistor that is item 241 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210406&diagram_id=22357332#d22357332 that can possibly cause the problem.
Thermistor Image:
http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfNTIwMDFYNTVSVy9IRUcvc290b2hwdHJhcC8%3d
If the defrost heating element is good then this would be suspect #2.
I hate to use someone elses material in a response but this one is so good that it is a must read:
http://www.appliance-repair-it.com/refrigerator-thermistor.html
Bottom line... I still think you have a defrost heating element problem at this time.
Thanks for choosing FixYa,
Kelly
Jan 27, 2011 | GE GSS25JF Side by Side Refrigerator
I now have same problem as arjaybeee posted on Oct 29, 2009 PFS22SISBSS digital temp. control LEDs not lit, so can't see the settings for fridge or freezer spaces. The spaces are being cooled, though, but...
It may be as simple as a blown lamp bulb.
Check item #624 on the diagram at this link. You can also order your part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218255&diagram_id=26230025#d26230025
Jan 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
