Question about Hitachi Televison & Video
Dark picture after changing bulb
I changed the bulb on my hitachi 50v720 rear projection tv and the picture is still dark. Could I have another problem?
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If not bright again and not a generic bulb-possible problem with the lamp ballast that powers the lamp.
Posted on Nov 06, 2012
  • 1694 Answers
SOURCE: 46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Posted on Feb 05, 2008
  • 80 Answers
SOURCE: Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Posted on Oct 16, 2008
racer7x
  • 42 Answers
SOURCE: hitachi projection tv.7years old.can i clean or change the bulb,w
Remove the front screen
Carefully Remove it
Pull the bottom off
Then remove the screws on the bottom of the screen
when you have them off lift the screen assembly up
be careful of the wire going to the panel
you can move the screen to the side and gain acces with out unplugging the wire but again be careful
clean the mirror and the projection bulbs
with glass cleaner and spray only on to the rag not the mirror or projection bulbs
Put it all back together and your picture should be bright as before
Posted on Feb 10, 2009
  • 65 Answers
SOURCE: chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Posted on Apr 22, 2009
  • 80 Answers
SOURCE: TV red spot
Your light engine is going bad.
Posted on May 21, 2009
Blue Cloud in center of tv after changing bulb
So you're TV is Sony not Hitachi? if your tv is Sony can you please give ys the model of the tv so we can help you better on this concern....
Aug 31, 2008 | Hitachi 50V720 Television
Hi I have a Hitachi 50v720 and I just replaced the bulb with the Phillips UX21517 bulb. When I turned the tv back on the picture worked fine except everything has a yellow tint.
I don't know if this set is a DLP or not, if it is, it could be your light engine. Not good, mine had a yellow halo about 2in thick in the middle of the screen. Light engine had to be replaced. Hope this is helpful. GOOD LUCK!
Oct 31, 2009 | Hitachi 50VF820 Projection TV
How do I change the bulb in my 50V720
Regarding your modle number, you tv part number is UX21517, so here's a video and picture guide of how to replace it.. .
http://guides.fixyourdlp.com/hitachi/UX21517.php
Jul 16, 2009 | Hitachi Televison & Video
Chage bulb tv is still dark
Apr 21, 2009 | Panasonic PT-52LCX66 Projection Television
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Hitachi HD 53" digital projection tv
Good Day; brannie1;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 53FDX01B 53" Rear Projection...
HitachI HD DIGITAL TV 53"
Good Day;
Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Oct 17, 2007 | Hitachi 50V720 Television
Hitachi rear projection TV
picture has gone dark, but not completely away, would this likely be a bulb and how do I change it?
Sep 09, 2007 | Televison & Video
Televison & Video Logo
188 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
