Question about Brother ML-100 Typewriter
Brother ml 100 can't get it off the correction tape mode
It will only type on the correction tape. I can't get it to type on the black ribbon.
  • Brother Master
  • 3,594 Answers
First remove the correction tape, then turn it off and back on and let it do it's reset, if it will now type OK check to be sure you have a dry L/O tape, if it is at all tacky replace it with a dry L/O tape.
Posted on Jan 05, 2009
Typewriter does not correct
There is a cam cluster under the ribbon plate that has to move over when you hit the correction key this lifts the correction tape, make sure the lift is not working and that the correction tape is old, and just does not lift off, have seen that...
Mar 21, 2014 | Brother ML-100 Typewriter
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
I have a Brother ML 100 Standard I changed the ribbon on it and now I can't get english language to type on it. Please help
Check to be sure the ribbon or L/O tape aren't tangeled in the P/W, check the P/W for bent spokes.
DickyO
Nov 11, 2010 | Brother ML-100 Typewriter
The correction tap will not pick up all ink?
When the correction dosen't work the ribbon and or the correction tape are old. Put a fresh ribbon and correction tape on. Not one that has been sitting on the shelf for years.
DickyO
Replacement ribbon
your office supplie store should have them. it is a common corr. tape if you look at your ribbon there is a colored knob on it ( orang, yellow or blue ) buy the same color. make sure you have a low tack corr. tape. if can't fined one we sell them 320-251-0092
Jan 29, 2009 | Brother ML-100 Typewriter
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correct key
Jul 07, 2008 | Brother ML-100 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
