Question about Bosch Dryers
BOSCH NEXXT SERIES GAS DRYER WTMC3500 LINT FILTER LIGHT BLINKING AND WRINKLE BLOCK FINISHED LIGHT IS ON STEADY WHILE TIME LIGHT READS 000 WHAT IS GOING ON
ITS NOT THE FILTER OR THE EXUAST THEY HAVE BEEN CLEANED REALLY WELL IVE TRIED THE RED RESET BUTTON I HAVE CHECKED THE BELT , I CAN SET THE DRYER TO OFF HOLD DOWN THE START BUTTON AND THE DELICATES BUTTON AT THE SAME TIME WHILE THEN SETTING THE DRYER SETTING KNOB TO A SETTING AND GET THE DRYER TO SPIN SO IT WORKS BUT NOT RIGHT SOMETHING IS HOLDING ME BACK
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
Bosch Nexxt 500 series dryer, E:01 and lint light flashing. nothing is stuck in the door.
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 26, 2010 | Bosch Nexxt 500 Dryer
Lint filter not allowing dryer door to unlock
Try unplugging it for an hour.. Might reset it..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch dryer not workin
Sounds like the dryer needs a good cleaning inside the workings area. Have a technician take it apart, and have a vacuum handy to **** up all the lint. While in there, he can check the working parts.
Apr 24, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt Dryer won't Start
Check your door switch - it might be broken. There is a small stud that protrudes at the top of the door that pushes into the switch (inside the dryer itself) If the any of those parts don't align well, or if the switch attachment is broken, you'll get the symptoms you've described. It's pretty easy to take it apart to check 0 make sure you get the top off first, and make sure you remove all the caps covering all the screws - they're easy to miss
Mar 17, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Dryers Logo
43 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
