SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
SOURCE: replace washing machine bearings
It is a very involved process with the tank having to be extracted form chassis. There is really no step by step instructions for this, but most reports say it is not economical to do this yourself. There may even be restrictions in your zip code. You should hire a technition to do this and the job takes about 2 hours.
I hope I was able to fixya problem and I wish you the best with this.
SOURCE: Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
SOURCE: noisey drum, can bearings be replaced on zanussi zwf 1421 w
Yes they can. Search for a service manual for instructions, on the net. Parts are not usually exspensive, Repairmen are. I did mine in less than an hour.
Andy
SOURCE: Hotpoint WMA66 Drum Bearings gone. Drum will not ...
Here are a series of free videos to help you with your
bearing problems and how to fix them
For all your free videos on appliance repairs remember to
mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings
in the drum tub
the last one will show you how to change the spider or drum
support as they are known
