Question about Dryers
I have a Frigidaire Dryer (FER231AS2) and the blower wheel seems to melt against the housing when I am just doing a timed dry (fluff) on high heat. I have broke it loose and ran sandpaper around both edges to smooth any potential rubbing issues but it will do the same if I run a cycle on high heat again. Regualr drying with the cool down cycle seems to work fine. I purchased a new blower housing and fan but I do not want to replace it if I should also replace something else. Could this be some sort of heating issue?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
You will need to replace the blower. Here is the part to order.
Posted on Nov 06, 2012
  • 159 Answers
SOURCE: Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Posted on Jul 13, 2007
  • 21 Answers
SOURCE: Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Posted on Sep 08, 2007
efriend
  • 15 Answers
SOURCE: Maytag dryer
Dear sloika,
I do not believe the problem lies within the dryer unit.
when the dryer unit fails to dry clothes in reasonable time 90% of the time it is the clogged air vent is the reason.
Dryer vent cleaning improves the safety and efficiency of your dryer installation. As dryer vents become filled with lint and other debris, drying time increases and can cause the dryer itself to overheat. This increases energy consumption since the dryer has to run longer to dry your clothes and can also cause fires in the dryer or the dryer duct. The Consumer Product Safety Commission reports dryer related home fires are on the increase.
  • First check your vent hose between the back of dryer and the air outlet on the wall. Vaccum clean the dirty hose and even into the dryer unit using flexable vaccum attachment. also try to vaccum clean airoutlet that goes into your wall as far reach into and much as possible. The dryer's lint filter and its path needs to be cleaned as well.
  • If all air flow path are cleaned it will improve 200% of your drying time.
There is also professional dryer vent cleaners in your area who can help solve the problem. just check your yellowpages..
Posted on Feb 16, 2008
  • 14 Answers
SOURCE: dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Posted on Jul 25, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
Frigidaire dryer heating up but not completing cycle.
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 07, 2015 | Frigidaire Dryers
My dryer won't dry
This particular dryer has a blower wheel that is plastic. Over time the wheel gets wobbly and loose. If you hear a rattle that could be the loose blower wheel. This causes the dryer to overheat and take 3 times as long to dry clothes because it trips the limits. To get into the dryer and find out you need to first remove the door. Nice how to video from Angel:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 13, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My LG Tromm electric dryer won't heat - again.
if the high limit is popping the dryer is getting to hot,i know you say you checked the vent line but i've heard that before,when i get out i remove the vent from the back of dryer,change out the t-stat and run it with the vent line off and it runs fine,how long is the vent line?if it's a long run remove it from the back of dryer and stick a leaf blower into it,blow it out to the outside and see what comes out,also first run it on air fluff,if this is a newer dryer set it to timed dry and then you can set it to air fluff,go outside and feel how it blows,then after you blow it out check it again,if you see alot of lint blow out and it's blowing harder your all set,you should take the dryer apart and clean it and the vent line once a year and you won't have any problems like this,also you won't have to worry about a dryer fire,your clothes will dry on time and less parts will have to be changed out,also when you get it to heat again run it on air fluff,if it gets hot on air fluff you have a shorted heater,one of the coils are touching the metal box on the heater and the heater won't shut off,also you have to clean out the duct where the lint filter slides down into,if this is blocked the dryer can't push the air out the blower wheel is blocked with lint.hope this helps you out happy holidays
Dec 25, 2017 | LG Tromm Electric Dryer
Frigidaire dryer blower fan keeps getting stuck.
Since you didn't leave a model number, I will have to give you a generic answer, instead of one with a part number of the most likely replacement part. Normlly the problem you discribe is a result of the blower motor bearing wearing out and letting the fan blades rub against the housing. And since the bearing is internal to the motor, you have to replace the entire motor.
Dec 30, 2011 | Frigidaire Dryers
Neptune dryer turns on and works for about 10 minutes, then shuts off. When the door is opened it is very hot and has a burnt smell. The only setting that does not have a burnt smell is air fluff. All...
remove the front cover and drum and clean out all lint including lint filter blower wheel housing and all exhaust vent piping from inside dryer to outside discharge,if this is done and it persists,replace the cycling switch and high-limit thermostat as these may have welded themselves and can no longer control heat
Aug 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont heat up
Hello
If the dryer wont heat up and dry clothes it means that the thermostat, located on the blower wheel housing inside the duct, needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 16, 2010 | Frigidaire Dryers
We have a gas dryer purchased in 1996, Model #CDG800W. The dryer has started to make a strange grinding sound when we're drying clothes. Any suggestions?
Most likely a bad blower wheel. Over time the hub gets hot, melts, wobbles out, and start to rub the blower housing. The wheel slips and makes it take a long time to dry the clothes. This causes the filter to warp and the top to get extremely hot.fdd151b.jpg513b315.jpga1f312f.jpg77fbb60.jpg
I have posted more repair photos here
Nov 01, 2010 | Crosley Dryers
I have to dry my clothes t 2 or 3 times before they are dry
Off hand I would think that you are not getting either the proper amount of heat (or no heat) or you have plenty of heat and insufficient airflow to release all of the moisture outside.
Both of the above possibilities are connected to airflow. Most dryers when the air ducts are restricted will burn out their thermal fuse, thus you don't have any more heat to dry your cloths.
Check your dryer venting outside when it is running, see if you are getting a healthy amount of air coming out, it should also be a good deal warm if it has been running for a while on high heat.
If it is warm and not much air, stop your dryer immediately so you do not burn out your high temperature limit fuse. Then disconnect the dryer hose from your dryer, start the dryer again (no heat setting) see how much air is coming out. If it is significantly more, you'll need to clean out your dryer venting in the house, if still low, the dryer itself is plugging up and needs to be cleaned from the lint trap to the blower wheel. (90% or more of the time they do not plug up after the blower motor to the back of the dryer.)
Hope this helps
Oct 26, 2009 | Whirlpool Dryers
Gas dryer does not seem to heat up takes a long time to dry clothes.
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 12, 2009 | Dryers
My admiral dryer just stopped heating what can the prob be.
It might have a problem with the blower wheel or lint in the filter housing. Before it quit did it take a long time to dry clothes? That is a sure sign of a dead dryer high limit failure. Located in the rear of the dryer beside the heater element you will find the limit. 4e6fab4.jpg
from there you can get the front and drum out and locate the problemo on back. be sure to check the blower wheel fer looseness and git all that funk out dat dryer.
Sep 03, 2009 | Dryers
Dryers Logo
83 people viewed this question
Top Dryers Experts
