Question about ASUS U52F-BBL9 Laptop
Asus icore 5 s.m.a.r.t error
So I have no idea how this happened...My computer all of a sudden said that there is a S.M.A.R.T error; repair and backup need to be done. I tried getting into F5--ITS ALMOST IMPOSSIBLE-- I basically keep finger smashing all the function keys because that's the only way to get to the options. Now I tried Safe Mode; it loaded up until the Command Prompt showed up and then nothing... :( this is a brand new computer (refurbished from tigerdirect.ca) ten days ago--- what's going on!!!!
  • rasniezko
    rasniezko Nov 05, 2012
    Oh and just now I tried "Last Good Configuration" and Nothing. The mouse is shown behind a blank black screen!
  • ASUS Master
  • 7,627 Answers
S.M.A.R.T is a HDD program, http://en.wikipedia.org/wiki/S.M.A.R.T.. Have you tried a system restore/recovery? If it's ten days old send it back for a replacement, do not wait. They should send you a replacement. Be Persistant. Do not take no for an answer.
Posted on Nov 05, 2012
parrotheadpc
  • 2600 Answers
SOURCE: black screen folowing options. safe mode etc. asus Eee pc 904hd
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Jan 18, 2010
SOURCE: Asus Eee PC 1005HA - Windows won't Start
i have the exact same problem. those solutions cannot help me. i dont have any hardware installed or anything plugged into it besides the power cord. also it doesnt have a cd drive so i cant put that xp cd you were talking about. what else can we do to solve this problem. i cant get past that screen to do any of these solutions. please help
Posted on Feb 14, 2010
SOURCE: When Windows XP tries to load, I get the following
Enter in "Last known good configuration. Then Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" . Then right click on my computer icon click on property then click on hardware tab then click on "hardware profile tab" Then select another profile is there is 2 profiles then apply and check but if there is only 1 profile then you need to create new profile with below method. Click Start, click Control Panel, click Performance and Maintenance, and then click System. On the Hardware tab, click Hardware Profiles. In the Available hardware profiles box, click Docked Profile or Undocked Profile, and then click Copy. Type a name for the new hardware profile, and then click OK. Click the new profile, click Properties, select the This is a portable computer check box, and then select the best description for the profile (the docking state for the profile). Click Always include this profile when Windows starts.
Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 29, 2010
  • 130 Answers
SOURCE: My ASus eee pc is
Ok-Go to Safe Mode-any-click on start menu-run:msconfig-hit enter-click on restore option-choose date-go! If you can't do that, on boot you machine should tell you what other option you have-like"push ESC button to aces setup" or something like that. Hit that button and go to RESTORE function.Good luck and Happy Holidays!
Posted on Dec 27, 2010
  • 107 Answers
SOURCE: My ASUS UX50 laptop has
Seems like there are Operating System files that got corrupted. Try to boot the PC into the Windows OS setup disk. Run the setup, choose the currently installed Operating System then select Repair. For more details please check this link - click here
Hope this help. Goodluck!
Posted on Mar 28, 2011
My asus notebook PC will not do anything but load up to asus logo screen and the cursor! What do I do??
It's likely that the disk-drive has failed, and Windows cannot be read from the disk-drive to "boot" the computer.
Take the computer (and power-adapter, if it is a laptop) to a qualified computer-repair place.
I hope that you have been making good "backup" file-sets.
Aug 21, 2015 | ASUS Computers & Internet
ASUS Computer
Activate S.M.A.R.T. at bios is not active
Do a Hard Drive diagnostics
Think You Might Have Hard Drive Problem Test it for Free
Test your RAM with Windows Memory Diagnostic tool
Test your RAM with Windows Memory Diagnostic tool CNET
Backup your data while you can
then to at CMD: chkdsk c: /F
Sometimes repairs bad HD sectrs.
If you have serious Hard Drive problem, you should replace it.
Now, somehow I suspect your problems could be RAM memory.
May 24, 2015 | ASUS Computers & Internet
Asus p5w continous beeps from internal speaker
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5W%20DH%20Deluxe&p=1&s=22
A component on the mainboard, could have a defect.
This could be a ram module overheating, or the power supply is too small, or overheating.
The mainboard supports 4 x 240-pin DIMM sockets support max. 8GB DDR2 800/ 667/ 533 ECC and non-ECC memory.
Try to blow the pc out for dust with compressed air, and update the mainboard drivers, and the bios to the latest version. And try to renew the thermal paste, between the cpu and the cooling element.
Or simply the mainboard has a internal defect.
Good luck
Feb 10, 2013 | ASUS P5W DH Deluxe Motherboard
Ahci port0 device error
This indicates the hard drive is bad and close to failure, backup all critical files, test the hardware for errors using windows tools, it can repair files and attempt repairs on bad sectors.
May 28, 2012 | ASUS Computers & Internet
This is a Compaq Presario CQ62. It is 3 months old. The orange Compaq screen pops up but then the computer shuts down after just a few seconds. Have tried it unplugged, plugged in with and without the...
Simple test to determine if it's a hardware or software problem : try to boot in the BIOS. If you can't then it's hardware you should just return it, it's still in the warranty. If you can then Windows is totally corrupted so just reinstall it.
Dec 19, 2010 | Compaq Computers & Internet
My Computer, Asus was can't started to Windows ,
Please save your backup if you can and then format your computer.After formatting your computer please install a good anti virus
Thanks.
May 30, 2010 | ASUS Terminator P4 PC Desktop
New laptop wont start stuck on asus screen
This just happened to me today. My notebook is the same model. I was logging into a game and all of a sudden it blue screened. After that every time I restarted it would go to the Asus logo screen (I think that's what is referred to as the splash screen but could be wrong). No keys worked. Nothing I could do. So, I called Asus and they had me unplug the power, take out the battery and hold down the power button for 10 seconds. Now it's fine. Apparently it just needed to be reset. I hope that helps. Good luck.
Jun 18, 2009 | ASUS MyPal A639 Pocket PC
World of Warcraft Error #0
You have to repair your game.
1. Go to the Repair Tool in World of Warcraft folder > repair.exe
2. Right Click the World of Warcraft Shortcut > Properties
3. Click Find Target button in the bottom left of the Shortcut tab. This will display the World of Warcraft folder.
5. Double Click on Repair program and choose the Reset and Check files option.
6. This will create a backup of your WTF, WDB and Interface folders before resetting them and then begin scanning your installation.
Aug 24, 2008 | Blizzard Entertainment World of Warcraft...
ASUS U52F-BBL9 Laptop Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
