Question about Retail Supplies
Get error 01 when i press scale key on sharp er-a450t cash register
  • 3 Answers
SOURCE: SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Posted on Jan 26, 2008
greg_margo
  • 1959 Answers
SOURCE: can't change the tax rate on a Sharp ER-2386 cash register
The amount that goes in the blank is the minimal amount that the tax can be applied. Put the number 1 in the blank to indicate all sales over $.01 will be taxed. Also, 8375 won't work. It's looking for a 5 digit number so if you're trying to indicate a 8 3/8% tax rate, it should be entered 83750. Post back if you have any questions.
Posted on Apr 13, 2009
flexion1
  • 737 Answers
SOURCE: ERROR E32 SHARP ER-A220
hi. E34 means the machine has had a limit programmed into it so that a maximum price can be entered. this stops staff accidentally charging say $1000 instead of $100. Try entering a lower price. The limit can be removed if desired. Mark
Posted on Jun 13, 2009
SOURCE: My Cash Register Sharp ER-2386 show me just a 0
YOur register lost the program or it has no battery power and was left unpluged. If you do a master reset it will all come back. At the moment it is most likely the program is corrupted and needs a master reset. It is done by turning the key (if you have a service key) to the blind position and holing down the journal key and plugging the machine back in, oh yeah you are suppose to pull the plug first. then program in the time and date and what ever else you may wat
Chris
Posted on Jul 07, 2009
flexion1
  • 737 Answers
SOURCE: sharp cash register (er-a470) won't turn on.
If the machine is dead, then you probably have a bad battery. It should be changed every 3 to 5 years by the dealer. If it has been left too long, then this is a common symptom and the machine loses all programming. Otherwise, you may have a faulty power supply or mode lock unit. It sounds like you need to see a dealer about it. ------------------------------------------------------------------------
If anyone is looking for a Sharp ER-A470 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Many more available at
Posted on Mar 28, 2010
I have a sharp ER-A450T it is frozen and I have followed all the trouble shooting things in the manual and nothing seems to work...please help
Hi Renee. The first thing to check with this model is whether it beeps when you press clear (The C button near the number 9 button). If it does not make a beep sound, you are right, it is frozen and the problem is usually either a faulty keyboard or printer (but you usually have an error code or dashes on the display if printer problem). Take it to be repaired.
If it does beep, it is not frozen and it is probably just waiting for you to finish something you started. Try pressing clear (C button near the number 9 button) in each mode and then press subtotal and then cash. So turn key to REG mode, press C SUBTOTAL CASH. Turn key to MGR mode, press C SUBTOTAL CASH and so on for each mode. If it shows an error message, please let me know which one and we can check further
May 09, 2017 | Retail Supplies
How do i fix a error 32 on a sharp er-a450t
You haven't logged on. Type your secret clerk PIN number then press the button marked "CASH#". If you don't know the PIN number, you need the dealer manual:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A450T_programming_manual.html
Mar 10, 2014 | Casio Parts Cash Register PC Desktop
I GET ERRO CODE E32 ON MY MODEL #ER-A405T AND NEED TO FIND OUT WITCH KEYS I MUST PRESS TO ASSIGN A CLERK #
I think you mean an ER-A450T. Try pressing 1 then CASH# button (usually next to the JOURNAL FEED button. Not the CA/AT button)
If anyone needs a Sharp ER-A450T manual, try this page:
Apr 02, 2010 | Casio Parts Cash Register PC Desktop
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
Retail Supplies Logo
23 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Are you a Retail Supply Expert? Answer questions, earn points and help others
