Question about Panasonic DMR-ES40V DVD-Video Recorder
F60 Error message on DMR-ES40V unit
Screen message 'F60'. Have attempted:
1. Holding power button down for 10 seconds to reset unit. Had no
success.
2. unpluged unit for 1 minute then plugged it back in. '00 00 00' appeared then disappeared but 'F60' reappeared.
Can you tell me how to fix this issue.
Thank you
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Posted on Jul 22, 2009
    Problem Solver:
  • 6 Answers
Try holding down the channel up and channel down button on the unit itself simultaneous and continue to hold until the unit turns off. This resets the unit. If your error returns, go to the Panasonic website and download the updated firmware on a cd and put it in your dvd player. (instructions are on the website) found all of this out trouble shooting tonight. Hope this works for you. - Tamara
Posted on Jan 10, 2009
Panasonic dmr-es40v
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
Jul 08, 2016 | Panasonic DMR-ES40VS DVD Recorder/VCR
When powered on, code F60 shows on player and nothing works.turned on and off and also unplugged for 10 seconds but doesn't reset.
With the unit powered off, press and hold the Stop and Channel Up buttons while powering on the main unit at the same time for about 5 seconds. This hoepfully will reset everything
Oct 03, 2015 | Panasonic DMR-ES40V DVD-Video Recorder
After power up, error code F60 is all I get. What's F60?
After reading and trying these solutions with out success, what I did was climb to the top of my roof and throw the Panasonic unit onto the cement driveway. The end result was the unit still won't work but darn I feel much better. No Mo Panasonic electronics for me, thank you very much!!!!
Sep 19, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Jul 17, 2010 | Panasonic DMR-E85H DVD Recorder
DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
DMR-ES40V Error Code F03
This means there is a technical error.
I suggest you go to your nearest retailer iof this and they will fix it but they will probably charge.
Hope this helps! - Josh
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Sep 02, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Televison & Video Logo
2,786 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
