Manual for Goj 12331 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Google model number of unit with "manual" to try to locate one or contact maker of set.
Posted on Nov 06, 2012
What do the letters "DEW" mean on the screen. TV/VCR combo model GOJ 12330
DEW means that there is condensation inside the unit. Turn it off and unplug it for a few hours. The unit needs to reach equilibrium with the temperature and humidity with the room. The TV is cooler than the room and the moisture will continue to be a problem until the components of the TV reach room temperature.
If you fail to allow the TV to reach equilibrium, some components may become damaged by the moisture. If that has happened, resolving the error may take major repairs. Electronics do not like moisture.
I hope this helps.
Jan 23, 2015 | Televison & Video
I recently received an admiral tv and i was looking for the audio and video jacks/ports and could not find any... are there any ports? it is n admiral tv and the model # is GOJ 12028
If there are no A/V jacks on the set you can get a RF modulator. They are cheap on Ebay and work great. All you would do is plug in your A/V plugs into the RF modulator and then plug in a coaxial cable on the output of the box then plug the other end to the input coaxial cable jack on the TV. Make sure your TV is on the channel your RF modulator specifies.
Aug 31, 2012 | Televison & Video
How do i get my netgear wireiess-150 router to work
kb.netgear.com/app/answers/detail/a_id/12331
Hi, it;s all in the manual above..it shows you how inside.
basically, hook up via an Ethernet, use a browser, to address the router, and login then simply enter your ISP details etc. and you should be all good.. As I said have a look in the manual.
Aug 09, 2010 | Computers & Internet
We have a Kyocera FS3830N - message install MK -
MK is the maintenance kit. You can check the Kyocera site to find out where to get a new kit and how much they are:
http://usa.kyoceramita.com/americas/jsp/Kyocera/products_printers_details.jsp?pid=12331
Most of the time the message is just displayed because the machine has reached a certain number of pages, but it should still let you use it normally.
May 27, 2010 | Kyocera Mita FS-3830N Laser Printer
Unable to find a code for an admiral tv NO.GOJ
Most universal remotes work the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 23, 2009 | RCA 3-Device Universal Remote
36'' Admiral fuzzy picture model GOJ 12390
you'll have to take the back off the tv and on your right you'll see two black button on the flyback transformer one over the other the other the top button is for the focus you can bright or darken the image on your screen don't be afraid it will not bite as long as you don't touch nothing but the button with a phillips screwdriver and don't have the kids around when you are doing it
Jan 15, 2009 | Televison & Video
LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Dec 30, 2007 | Washing Machines
Lg washer dryer
The DHE error is dryer heat error. It's a problem with the heating element or thermister. You can find the service manual herehttp://www.appliancefactoryparts.com/content/pdfs/129017-8.pdf
Nov 11, 2007 | Washing Machines
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
