Question about Null Heating & Cooling
Gas furnace won't heat
Hi, I'm really hoping you can help me. I have a weatherking acclaim ii gas furnace. I have not been able to locate an owner's manual. The fan is blowing but no heat. Here's what I've got: http://s10.postimage.org/ttcphlezd/DSC00426.jpg When I first power the unit, the two green LEDs on the board go solid for about 2 minutes. (see video 1). After about 2 minutes, one of the green LEDs starts to flash. I cannot smell gas. The honeywell gas valve is in the "on" position. Here is what happens upon startup http://www.youtube.com/watch?v=Vmf7a99RP88&feature=youtu.be And here is what happens about a minute and a half to two minutes later. http://www.youtube.com/watch?v=27qtXOQy2Gs&feature=youtu.be Circuit board has the following stamped on it: 62-2400-1-02 Any ideas?? Thanks in advance for any help you can give me!
4 Suggested Answers
coldhourz
  • 199 Answers
SOURCE: Display Stops after 5mins
As a follow up to Benimur's post and if you are considering a DIY, the following might be of further help:
  • a cleaning of the inside with the use of a can of compressed air and a vacuum cleaner;
  • source of Service manual;
  • correct user's manual;
  • often the problem is heat related or sensor(s) erroneously reading false temperature;
  • to my knowledge the NEC MT1050 uses a JED T460 projector controller with several smaller PCBs for various sensors. A possible source of parts.
Cheers.
Posted on Aug 18, 2008
rockitman187
  • 2559 Answers
SOURCE: WeatherKing Acclaim II
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Posted on Jan 16, 2009
SOURCE: Why Wont My Bryant Furnace Stay Running
You have a dirty flame sensor, it needs to be replaced
Posted on May 03, 2009
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Nov 25, 2012 | Honeywell VisionPRO Thermostat TH8110
What is the door switch on the weatherking acclaim II Furnace that allows it to go on and off?
When you pull the panel off the blower compartment there is a switch that verifys this panel is place. Its called a door switch although you are putting the blower panel on. Its usually black and has the hot incoming line voltage that runs through this first. Thanks Happy Heating
Dec 11, 2010 | Heating & Cooling
Igniter keeps breaking
Wow, this is a new one on me! Are you using true OEM parts for your source? If not, you may be getting sub standard parts. There are some companies that use generic parts and this isn't a good thing to do sometimes. Weatherking is a Rheem/Ruud product.
Apr 10, 2009 | Weather King 12AJA4801AH Air Conditioner
Jan 16, 2009 | Heating & Cooling
Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Nov 30, 2008 | Weather King 12AJA4801AH Air Conditioner
not only the jets but you need to change the spring in the gas valve and cut the pressure WAY back to prolly 3.5"wc
Nov 22, 2008 | Weather King 12AJA4801AH Air Conditioner
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
Heating & Cooling Logo
109 people viewed this question
Top Null Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Null Heating and Cooling Expert? Answer questions, earn points and help others
