Question about Canon ImageRUNNER 3235i Black and White Copier
How do I scan to a usb on the Canon ImageRUNNER 3235i
I have an external USB hard drive that I'd like to scan all paper documents and save them directly to my HP external hard drive. How can this be done?
5 Suggested Answers
gunninfo
  • 59 Answers
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
  • 32 Answers
SOURCE: can i scan and save
yes instal the (scan drive gear tool)
Posted on Feb 04, 2011
canontech
  • 1219 Answers
SOURCE: Hi there. Our Canon
These can be a quite pain, this copier when it works it works it fine, but when it doesn't works it doesn't work with style.
Please give me more info, where the paper is skewing? in duplex assy or before or after the fixing unit or while going out of paper drawer...?
I had a problem that paper was skewing in duplex and I've chaneged the duplex vertical roller axis.
Posted on Sep 21, 2011
Testimonial: "Most knowledgeable person I've communicated wtih! Thank you!"
  • 149 Answers
SOURCE: how can i scan document
Your exchange email server must be programmed into the copier with a username and password under network settings, which is an administrative function.
Posted on Oct 16, 2011
I have canon ir2270 it's connected through a usb cable. how can i scan a document?
To scan any document with machien first of all u have to need connect ur machine with ur compuer via cross cable,
Dec 29, 2012 | Canon ImageRunner 2270 | IR2270 |
Can't use
Just plug it in to your computers usb port make sure its connected properly
An example on how to download and save to an External Hard Drive and copy and paste to an External Hard Drive Click start all programs accessories open windows explorer navigate to your data
Right click on the data select copy navigate back to the External Drive.
or right click on the data select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet.
Once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into your External Drive or a folder in my documents or another device or a usb device
if you need more help with this post a reply Hope this helps.
Dec 23, 2012 | SanDisk 16GB Ultra Backup USB 20 Flash...
I can't download anything from my pc
usb device
Hope this helps.
Nov 24, 2012 | Computers & Internet
Need manual
usb device
Hope this helps.
There is no space on my hard **** pc i put all my doc on a hard **** ext put sill show full please help me brian
You could run the chkdsk utility
there are many ways or running the chkdsk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility or
Click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now, start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
For USB drives click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
this process can be done on your primary hard drive C:
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
you should have no input while the chkdsk utility is in progress any input may damage your computer and your hard / usb drive
then right click on your drive select properties to see how much space you have
then i would either transfer or cut and paste these documents onto either a pen / data traveller drive or an external usb hard drive
Personally i would go for the pen / data traveller i have heard of to many problems with external usb hard drives
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
or plug your usb pen / data drive into a usb port on your computer
Click start click on computer, you will see all of your drives. C: primary drive D: cd/dvd drive and E: or F: you usb drives
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the documents.
usually in my documents or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my personal docs 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the document, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
Sep 28, 2012 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
Please say someone has a solution for me, very worried i've most my life's collection of music and movies =[
Try the WD USB hard drive in another computer. If you can access your data on another computer then backup your data.
If the WD USB hard drive is faulty then -
It is not possible to recover data from faulty hard drivesby mortals such as you and I.
There are companies that can recover data from faulty and damaged hard drivesBUT they wll charge an arm and a leg for their services.
Feb 23, 2012 | Western Digital 1TB WD ELEMENTS USB...
Need instruction manual don't know how to use
Oct 27, 2011 | Kingston 2PK 4GB USB 20 DATATRAVELERI GEN...
HP nc6230 freezes shen loading Windows XP Pro
Try booting from your Optical Drive. First insert your Windows XP Pro CD into the drive. Do not re-install the operqating system or you will lose all your files and programs! When prompted press 'R' to use the Recovery Console. You should be able to write a new boot sector to your hard drive.
If this doesn't solve the problem, you might need to re-install the operating system. If you can find a way to save all your files from your drive (perhaps by putting your drive in an external USB caddy and viewing its contents on a different computer).
If all else fails get a new hard drive and start again with your WIndows XP Pro CD. Use an external 2.5" USB caddy afterwards to get your documents and files back off your old disk. You will need to re-install your programs, though. If your disk is Service Pack 3 you should be able to get straight back on the internet via a wireless connection to update all your drivers from hp's website.
Oct 27, 2011 | HP Compaq nc6320 Notebook
Hi there. Our Canon ImageRUNNER 3235i has been skewing papers about for months. Service techs can't seem to find the problem as it is sporadic. Any suggestions?
Sep 20, 2011 | Canon ImageRUNNER 3235i Black and White...
Canon ImageRUNNER 3235i Black and White Copier Logo
432 people viewed this question
old marine
old marine
