Question about Samsung SyncMaster 2233BW 22" LCD Monitor
WHITE DISPLAY ONLY WHEN I SWITCH IT ON - Samsung SyncMaster 2233BW 22" LCD Monitor
    Sergeant:
  • 349 Answers
First thing is to remove the 15pin cable completely and closely inspect the pins inside the connectors. Often these inadvertently are bent when inserting the connector. If any are bent, use a fine pair of strong tweezers to straighten the pins. Once this is done, carefully re-attach the PC and Monitor ends of the i/o cable and boot up your PC.
If this does not work as a solution, reload the monitor driver for your monitor. You can usually obtain that free from the manufacturers website after entering the model number of the monitor.
Good luck
Poppa
Posted on Nov 08, 2012
When i switch on my nokia n72 it shows only a white display....help me
The white display indicates that there is some problem in the LCD display of the mobile. If the mobile works and display only not working means, it ensures the LCD display is got damaged.
Some times white display happens due to firmware corrupt also. in that case mobile will not work you can confirm it by making call during mobile is switch on. If so update firmware.
Dec 23, 2010 | Nokia N72 Cellular Phone
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
My nokia 7610 shows white display.
its hardware problem. change display ic or reboll the display ic
Jul 05, 2009 | Nokia 1100
White display on the screen.
Its a software problem... Try to see a mobile technician maybe it needs to be reformatted...
Jun 17, 2009 | Sony Ericsson K790a Cellular Phone
White display on Nokia 6233
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Apr 08, 2009 | Nokia 6233 Cellular Phone
My Nokia 7610 Display is white after switch on
display problem change the display
Dec 06, 2008 | Nokia 1100
N70 White display
its about display connector.follow display wires & try to fix the connectors
Nov 03, 2008 | Nokia N70 Cellular Phone
Problem with display of Nokia 6600 mobile
my nokia6600 occurs same problem
when i switch off and then switch on the phone then display comes for the time i am using the phone. As i left the phone for sometime without pressing any key it again goes to that white screen mode..but phone is functioning .plz help me to rectify the problem.....
Jul 14, 2008 | Nokia 6600
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
