Question about Whirlpool Dryers
Dryer has power. the lights come on but will not start.
The dryer got very hot and stopped working. Now all i have is the light comes on when i open the door. I hit the start button and it beeps.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
catriver
  • 878 Answers
SOURCE: dryer stopped working
plumber, pop the top on the dryer by pushing on the two clips just under the top on each side. In the back you will see the heater. You want to check the high limit thermostat (this one sits on the top side of the heater) and the thermal fuse (sits on the side about 4 inches down. Unplug the dryer and check them with a meter. If either shows open (no continuity) replace them. Make sure your venting is not clogged up and the heater is not grounded or fractured. Part number for the high limit is 53-0771 and for the thermal fuse is LA-1053. Check these first...Catriver...post back. Unable to find your exact model, but I do have cye4000ayw. parts should be the same.
Posted on Oct 12, 2006
SOURCE: whirlpool dryer,duet
Problem: Push On Button, Press to Start. Click. Sensing. No Tumbling.
Solution: Called repairperson. Replaced Thermal Fuse (Part 3390719) and also suggested having venting system checked (ours vents through attic). Charged $198.00. This did not appear to be a problem that a layperson could fix, although a very handy person might be able to do it.
Posted on Feb 24, 2008
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
  • 27 Answers
SOURCE: I have a cabrio dryer and it will not start. It
control panel is bad, use your warranty and get it fixed for free since it is only 2 weeks old
Posted on Jun 15, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Posted on Jul 22, 2009
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
My kenmore 400 series dryer will not start. It has electricity the inside light comes on when I open the door. I push the start button and nothing happens.
There is a thermocouple on the inside that prevents the dryer from getting too hot. If this burns out this opens the circuit so the dryer will not work but all other functions will work.
Sep 23, 2010 | Kenmore 400 6943 Dryer
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Just stopped working still has power-inside light comes on and timer makes noise when you turn dial but does not start when you push start button
This sounds like the door switch. But it could also be the non-resettable thermal fuse inside. Open the door, depress the door switch until it clicks, and while holding it in see if the dryer starts.
Jan 05, 2010 | Whirlpool Dryers
Dryer will not start,put a new start button,
The dryer is electric? not gas? If so you may have 110 and 1 side and not on the other. Reset the breaker and make sure you have 110v on each hot leg. You say start button I assume you mean door switch for the light? Have you checked the bulb? If this is already yes to this point open the top up and look at the wires coming to the door switch 1 of them is most likely chewed into by a mouse or something. the light has to have power to it all the time the door is open no power no light because I dont believe it gets any power except from the main power terminals not the timer or anything else .
Mar 11, 2009 | Dryers
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Kenmore Elite Oasis Electric Dryer
i have the same problem only the drum light will come on i opened up the top console and found the tech sheet and after going thru the tech sheet with a multi-meter according to the results i will need to replace the user interface assembly, p/n 3407184. you too may have the same problem.
Jan 07, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
