Question about Kenmore Washing Machines
My kenmore washing machine model 110 91551210 over flowed and will not do anything now it makes a humming sound for about 10 seconds then it smells like its burning then it stops.
Large capacity heavy duty machine. model 110 91551210 9.8 amps 60hg 120 volts stock 15512
Destinova
  • 46 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Top Load Washer Won't Spin/Agitata
I am sorry to say that you WILL need a tech to come out and service this unit.  From what you are telling me it is either a dead short in the motor, OR one of the conntections got wet and cause a short.  BUT I would put my money on the motor, since this is a direct drive unit.  Sorry
Posted on May 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Posted on Mar 10, 2009
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
miket756
  • 2702 Answers
SOURCE: How much to fix my Kenmore Heavy Duty Extra Large
you need to ring round and find this out,,,one firm may charge the earth and yet another may be a lot cheaper,,,so sak more than one firm or repair man,
Posted on Nov 28, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Kenmore top loading large capacity washer
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Posted on Jan 13, 2011
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
Jan 13, 2011 | Kenmore Washing Machines
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore frt ld dryer, motor hums ,shuts off, does not trip brkr
see it all the time,the motor is getting to weak to start,that's why you get the hummming sound sometimes,you can check your locak used appliance store or maybe ebay has one,your model number is inside the dryer door,to sum it up it's the motor,let me know now you make out-mike
Apr 11, 2009 | Kenmore Dryers
Kenmore elite 240-363-01
Lift the lid and put a pen in the lid switch to hold it down and put it into spin. If you can stop the basket with your hand, the clutch is slipping. The gearcase leaks oil and it gets in the clutch causing it to slip and it's probably what you're smelling. Clutch and gearcase need replaced at this point.
Mar 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stops at rinse cycle-hums and has a smell.
Problem is with your lid switch which has to be replaced. This is if your filter is all clean.
Feb 28, 2009 | Kenmore 15864/15862 Top Load Washer
How do I find model number?washer just hums
Check the motor or the tub bearing. Something is frozen on your machine and not letting it spin. You can also check the brake or clutch and make sure it is not stuck. On the back of the unit when you remove the back panel you will be able to see everything that you need to get at
Feb 13, 2009 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
73 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
