Question about Refrigerators
Replacing freezer electronic control board with mechanical thermostat.
I'm the proud owner of an under-counter freezer with a defunct control board. I've tried long and hard to repair the board but with no success. I've now decided to circumvent the electronics by using a mechanical thermostat which I've ordered to suit the temperature range I require. So, a couple of questions. I assume the body of the thermostat is designed to be mounted externally. Ideally, I'd like to mount it near to the compressor to facilitate easy wiring. Am I correct in this assumption? How far should the capillary tube be inserted into the freezing compartment? My thermostat comes with 1500mm of capillary tubing and by my estimation (and considering my preferred installation position) approximately 700mm of the capillary will be sited internally, while 800mm will be external. Can anyone envisage any pitfalls with what I'm proposing?
    Problem Solver:
  • 21 Answers
Steve is smart, body therm might be near ref. box and capilaryneed ten cm..(thre inch..?)ferm contact where compessor start freezing in box.rest you imagine as well
Posted on Nov 05, 2012
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Hi On a
I don't see where you have changes the temperature sensor.
They do go bad and when that happens the board can get a false reading and think the fridge is colder then it really is. Then it does just what you are describing...
I would change it and see what happens...
I am still a bit concerned about the icing problem though... seems like you may have two problems...but I would get them one at a time and do the sensor first...
Here is the sensor for you unit
heatman101
Posted on Nov 02, 2010
SOURCE: Kenmore 596.58395890 side by side runs continuously
I have the same problem, did you figure it out?
Posted on Jan 26, 2011
Frezzer frozon
as you haven't mentioned the model number i have 2 options, Basically what is happening is that the thermostat is not detecting that the freezer has reached it's lowest temperature, So you need to replace the thermostat.
On some models the thermostat is a mechanical part which is quite cheap and easy to replace, on other models it uses an electronic control unit with sensor probes, these can be a bit more difficult to fix and the parts tend to be more expensive.
Mar 07, 2012 | Whirlpool Refrigerators
I have a Maytag ref. the freezer is working but not the refrigerator. Mod # B1954MES00
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Aug 24, 2011 | Maytag Refrigerators
My maytag fridgerator has suddenly stopped getting cold. My freezer is fine and stays cold. Troubleshooting it did not work. Please help.
Jul 30, 2011 | Maytag MBF 2256 Bottom Freezer...
Freezer fine, refriderator is warm
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll the board.
Part 49 in this DIAGRAM is your air duct.
Feb 05, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
Barley any cold air coming out.
Jan 24, 2011 | Refrigerators
Freezer is fine, refrig. side not cold at all
OR
Oct 19, 2010 | Kenmore Refrigerators
Freezer is cold but refrigerator has warmed up to 60.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Aug 31, 2010 | Maytag Refrigerators
Frig does not cool, freezer works fine
Apr 26, 2010 | Magic Chef Refrigerators
Freezer works but fridge side not cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Dec 06, 2009 | Amana DRS2462B Side by Side Refrigerator
Refrigerator section not cold but freezer working
Nov 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
