Question about RCA Televison & Video
My picture looks 3d or like looking in to a bubble and i can see shadows of the picture in red and green
I was waitching it and i hard a pop and then the screen bubbled on my what could it be
    Top Expert:
  • RCA Master
  • 14,553 Answers
Depends and a model number is needed to give a reasonable answer and suggestions.
Posted on Nov 06, 2012
SOURCE: Toshiba Theaterview HD 54 inch
Converge In the setup menu and adjust as needed
Posted on Aug 20, 2008
SOURCE: red and green shadows on
blue and green like rainbows across the TV
Posted on Dec 24, 2008
SD Tech
  • 14553 Answers
SOURCE: I get a red band on the left side, and there is a
If it is Mitsubishi WT-42313 IT USES two of the STK-394-250 CONVERGENCE chips.
If 3d both will need to be replaced and the set adjusted. Sometimes there will also be a bad resistor around them that gets taken out--easy to find.
You can buy a pair of the chips on Ebay for less than 20 dollars--total parts cost should be under 30 dollars.
If you cannot do the repair yourself--shop around your area---most shops are going to charge 300 or more for this repair.
This is a very common problem on projection sets--the heat gets one of the chips after 5-8 years and it fails.
Let me know if you have questions or need advice. I am here to help people---If this information helped you rate this solution as I do this here for free.
SD TECH
Posted on Nov 05, 2009
Testimonial: "Thanks! I am printing this out for the guy who will be doing the service on this tv. VERY Helpful! "
SD Tech
  • 14553 Answers
SOURCE: The picture is distorted. Looks like it is in 3D.
If you go into the customer menu and select convergence and it is skewed you need to remove the light box and replace both of the STK-392-110 CONVERGENCE IC chips this set uses.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--I can post them here if you think you or someone you know can do the repair.
Most shops get 300 or more for this repair--if you buy the chips on Ebay (I can tell you the seller to look for there) they and any other parts should total under 30 dollars. The fact that the set is still coming on means most likely just the two chips need to be replaced and the set adjusted with the Panasonic remote for this set.
If you have questions or want the instructions rate this solution and let me know and I will post them here---I do this here for FREE.
SD TECH
Posted on Dec 02, 2009
Testimonial: "Thank you. Very helpful! Is it an easy fix? What kind of tools would I need? Would appreciate any instructions you have available."
  • 418 Answers
SOURCE: 43FWX20B 43 in. Rear Projection Television: looks like 3d with blue shadow to right of images ...
Convergence ICs are bad. STK392-120
Posted on May 06, 2010
Screen resembles 3D look with predoment red and green to images - did the blue blub burn out and need to be replaced?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.By replacing all these parts on the tv convergence board to fixed it to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 05, 2011 | Mitsubishi VS-60803 60" Rear Projection...
Bowed red green lines at top screen. picture looks like it in 3d.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 28, 2011 | RCA HD52W59 HDTV Projection Television
The red in the picture is shadowing the rest of the picture giving it a 3d effect
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
I heard a pop and then the color was like looking at a 3d tv without the glasses
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 06, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
After a half hour of operation, the picture begins to shadow.
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Hitachi 50UX57B 50" Rear Projection...
Our picture is very blurry with a red and green hue and shadowing. What can I do?
if it looks like 3d, you have a convergence problem---you may find it helpful to post the brand and model number
Aug 08, 2009 | Philips Televison & Video
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
Red and green shadows on picture looks like 3D
Sep 14, 2008 | Televison & Video
Looks like 3d picture
Sounds like the convergence amplifier ICs . What kind of TV and what model number and I will be better equiped to help you.
Jan 13, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
