Question about Dryers
Take apart kenmore heavy duty 81160
How to take the back off this model
5 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 08, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Posted on Aug 12, 2008
SOURCE: Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Posted on Oct 07, 2008
  • 1122 Answers
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
Kenmore heavy duty plus dryer modle number 886573130 works fine just stopped heating up.
Gas dryer no heat means the heating element broke or fell apart, need to install new one, go to sears hardware and order a repacement....model # in hand.
Feb 22, 2015 | Kenmore Dryers
Kenmore heavy duty washer model awiz wiring diagram
There is a wiring diagram inside the washer usually inside the control panel.
Jun 26, 2017 | Washing Machines
I have a kenmore 70 series heavy duty 110 96573230. It doesn't heat up. Can't find where the thermal fuse. Where is it located? Do I need to unscrew the back?
Yes, you need to take it all apart. ( Including the back.)
All of the things that can cause your problem are in the back and the bottom of your machine.
There are actually about 3 to 7 things that can cause "no heat".
Not only the "thermal fuse", but also the heating element, and any of the "overheat thermostat switches" can have failed, beside the possibility there is a wire has burned in two.
You will need a testing instrument like a multi-meter or a volt-ohm meter to check all these out.
Be blessed.
Mar 22, 2013 | Dryers
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore heavy duty clothes dryer will not heat
Feb 25, 2009 | Kenmore Dryers
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Dryers Logo
104 people viewed this question
Top Dryers Experts
