Question about Maytag MEW6530DDS Stainless Steel Electric Single Oven
Maytag MEW6530DDS control panel
3rd time it breaks need a new control panel????:(
localwonder
  • 6784 Answers
SOURCE: Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Posted on Jun 03, 2009
kojak18
  • 31 Answers
SOURCE: Control panel on my Maytag MEW6530DDS not working
there are screws that hold the frame that holds the panel in place. they are usually 3 at the top of the oven. after removing them you take that piece off and you then take out the other screws that show themselves. it is kind of like a puzzle. one suggestion is to make a crude.drawing on cardboard of the oven and stick the screws thru the cardboard and then you will know where they go when you put it back together. learned that trick the hard way. and make a drawing of the back of the oven control board and make a diagram of it that shows where each wire goes so you will not get them mixed up when you put the new one in. we had to order the wiring harness that goes from the control board to the oven thermostat. it was back ordered for 3 months. if i had not made that diagram i would have been lost when i went to put it back together. went online and found an oven control board for $120 installed it and the oven has worked ever since. this oven has a bad setup that channels the heat right by the oven board and it ruins the control board.
Posted on Jun 22, 2010
kojak18
  • 31 Answers
SOURCE: Its a Maytag wall oven and I need to replace the operating panel
usually you take off the handles with screws and the front panel is screwed to the door or held on by clips or brackets.
marka19
  • 1430 Answers
SOURCE: I have a Maytag Wall
Price of the part is $208 and average labor rate is $78. Most companies also charge a service call fee, this is the charge to come to your home diagnose the problem. This fee can vary from 0 to usually no more than $75. Be sure to ask when calling for service. For a DIY try this link http://appliancehelponline.com/ovenerc.html
Posted on Aug 05, 2010
marka19
  • 1430 Answers
SOURCE: I have a Magtag wall oven MEW6530DDS model. The
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Posted on Sep 18, 2010
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
I have a Maytag Wall Oven bought 4-28-2006 Model MEW6530DDS SN 13363140EP. The control panel has stopped functioning. Can I get an estimate of parts and labor? Sincerely, Jack...
Aug 05, 2010 | Maytag Ovens
Jun 18, 2010 | Maytag Appliances 27" Electric Double Wall...
I have a Maytag in wall oven (part# MEW653ODDS). Only three buttons on the control panel are functioning (cancel, convection bake, and favorites). The oven seems to work properly, but the number of...
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Nov 03, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
MEW6530DDS keypad not working
Check out www.appliancepartssolutions.com for a good price on your control board.Have the part# available you need or click on their "live chat" feature for help.
Aug 06, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag MEW6530DDS Stainless Steel Electric Single Oven Logo
35 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
