Question about Westinghouse 32" Flat Screen Lcd Hdtv, Model Sk-32h635s
Picture for about 30 seconds but has sound. TW-5592W82003990
Is the only solution to replace the whole board
    Top Expert:
  • Westinghouse Master
  • 14,553 Answers
I would first take a look at the screen with set on in a very dark room with a flashlight---do you see a very faint image or picture? That would indicate a back light issue-----Good luck getting a board, I hear the company is again out of business.
Posted on Nov 06, 2012
How do you replace the ballast on a kdf e55a20
to change a ballast board its a bit of work and a tear down to get it in there . but first lets review your problem .
its cycling off every 30 seconds . id suspect a defective lamp or a power supply problem since it sounds as if the ballast board does fire . that's assuming that you do see something come up on the screen when it attempts to start if a ballast has failed it usually will make a noise or the set would almost go into a shut down . also how many blinks and what order are the events happening ?
Jun 14, 2014 | Sony Grand WEGA KDF-50WE655 50" Rear...
No sound no picture
Check and replace its main power regulator board.
Mar 31, 2013 | Sony KDL 40CX520 40 CX520 Series Full HD...
After 30 seconds the screen goes black and still has sound (no picture)
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
often that *needs* to be done in a service center as there are some adjustments to be made after replacement.
Hope this helps
May 07, 2011 | Polaroid TLX-01511C LCD TV
I have a westinghouse tv model number SK-32H240S the sound works but the picture dosen't if u turn the tv on the picture comes on for 1or2 seconds and goes out again
Hello Olga, this problem is normally caused by something on the power/inverter board (normally a transformer or a capacitor). If you are technical you can open up the TV and see what component is bad, you can normally tell because the component will leak or in the capacitors case be puffy. If you are not that technical you can also open the unit and simply pull all the plugs from the power/inverter board (big brown board on the left hand side when TV is facing down), take off all the screws, and replace the whole board. I can assist you with obtaining part #'s for this board if you would like just simply send me an email with the model #, serial # and TW # all located on the back of the TV as well as a brief explanation of what the TV is doing to westytech@westinghousedigital.com. Please rate my answer if it was helpful, have a great one.
Mar 28, 2011 | Westinghouse SK-32H240S Television
I turn on the TV and the green power light becomes solid but then after 30 seconds starts flashing and I never get a picture. thoughts?
Power board must replaced parts,like capacitors,puff up or burst open.Must know how to solders?Or changed the whole power board.Buy at Websites Shopjimmy.com,ebay.com.
Jan 16, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
KDS-60A2020 picture is intermittent. every minute
This sounds like a power board problem. It is likely that capacitors on the board are failing so they can only store enough charge to properly supply DC current to the video board for a brief time. A shop will most likely suggest that you replace the power supply board entirely. If it were my TV I would remove the board and replace the bad capacitors for a few dollars myself. Depending on your experience with electronics and soldering you may want to do the same. Otherwise having a shop replace the board makes the most sense - the labor charges to repair the old one would not be worth it.
t
Dec 05, 2009 | Sony KDS-60A2000 60" HDTV
Black screen but get sound. picture flashes every
This sounds like a power supply issue. TVs operate on DC current and therefore must have a power supply board to invert AC house current to DC as well as regulate the DC current supplied. Heat is created by this process and therefore certain components on power supply boards are prone to failure due to repeated overheating. I would suspect capacitors on the power supply board are failing so they are only able to store enough power to allow the video board to work every 30 seconds and then it shuts off again. You can replace the whole board but I have repaired these before for a few dollars and some soldering.
Nov 29, 2009 | Sony KDS-55A2020 55" Television
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Jan 01, 2008 | LG RZ-17LZ40 17 in. LCD Television
Westinghouse 32" Flat Screen Lcd Hdtv, Model Sk-32h635s Logo
37 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
