Question about Casio Calculator Graphing FX 9750GII Calculator
My Casio fx-9750GII wont dispay a table
I go to "table" then I put in the equation, I set the range, etc. then I push F6 which is supposed to take it to the table. All it says is "Dimension Error." I followed all of the instructions, but it wont display a table. Help?
  • Casio Master
  • 8,068 Answers
The message dimension error usually refers to instances where two lists do not have the same dimensions (number of elements)
I checked and the calculator gives condition error. Check the type of function you are creating a table for. Choose the type y=
Posted on Nov 07, 2012
  • 5421 Answers
SOURCE: I have a Casio fx-9750GII,
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
Posted on Jan 19, 2011
  • 8068 Answers
SOURCE: I have a Casio fx-115ES; I have followed the
Calculator should be in [MATRIX] MODE
Try the matrices 2X2 matrices matA [1,2,3,4] matB [5,6,7,8], Add them, subtract them, multiply them, take the square of each. If that works for these matrices, then it must be your data. Be careful with negative numbers. To enter those, you must use the change sign (-).
There is also the possibility that the instructions were misread.
Posted on Dec 15, 2009
  • 8068 Answers
SOURCE: how to factor a polynomial equation on casio fx-300es?
The Casio FX-300ES does not handle symbolic algebra. So it cannot factor a general polynomial expression. The methods can be found in any book on Algebra.
However if you are interested in approximate factorization of quadratic and cubic polynomials, you can use the calculator to do that. It can solve aX^3 +bX^2+cX+d =0 and the quadratic equations.
If you want to factor a cubic polynomial P3(X) = aX^3+bX^2+cX+d , you write the corresponding cubic equation as aX^3+bX^2+cX=d =0 , then you divide all terms of the equation by a to obtain
X^3+(b/a)X^2+(c/a)X+(d/a)=0.
You use the calculator to solve (approximately) this equation.
Suppose you find the 3 roots X1,X2,and X3. Then the polynomial X^3+(b/a)X^2+(c/a)X+(d/a) can be cast in the factored form (X-X1)(X-X2)(X-X3) and the original polynomial P3(X) can be written as
P3(X) = a*(X-X1)(X-X2)(X-X3)
You can handle the quadratic polynomial the same way.
P2(X) =a*(X-X1)(X-X2) where X1, X2 are the two real roots
Hope it helps.
Posted on Oct 17, 2009
  • 102366 Answers
SOURCE: I can't plug in "i" on my casio fx-115ES even when
By default the calculator only works with real numbers. To use complex numbers, press MODE 2 to switch to complex mode.
Posted on Mar 05, 2011
  • 15 Answers
SOURCE: casio fx-9750gII looking for factorial
press Option, F6, F3, F1 to find the "!"
Posted on Mar 18, 2011
Testimonial: "Thank you very much I finally found it after searching and searching through the manual!"
Hoe to Calculate nPr and nCr on a Casio fx-9750GII?
In Run/Mat screen, press the OPTN key followed by F6, the F3:Prob. The nPr and nCr tab are accessible. Type n then the relevant tab, followed by the r-number.
Oct 13, 2015 | Casio FX-9750GII Graphing Calculator
I do not know what a range is and where to find it on a Casio FX 9750GII Calculator
In statistics, the range of 1-var a data set is the difference between the largest value and the smallest. R=Xmax-Xmin
In functions: the range of a function is the interval (or the Union of intervals) of the real line where the dependent variable takes it values.
Ex: sin(x). Whatever the value of the independent variable x, the values of the function sin(x) are in the closed interval [-1,1]. The range of the functions sin(x), and cos(x) is [-1,1].
No use of a calculator for finding the range of functions.
Feb 04, 2014 | Casio Calculator Graphing FX 9750GII...
Fx- 9750gii ... I deleted the table on my table
If the table contains experimental (statistical) data that you gathered and put in a table on the calculator, then I am sorry to say that if table is deleted there is no way to get the data back. You will have to renter it.
However if it is a table connected to a function you graphed then the table can be regenerated: Type in the function anew, press the table function key, then graph it.
Oct 18, 2013 | Casio FX9750GII Graphic Calculator
Inputting inequality signs in equations on Y= graphing menu.
Choose one of the inequality type graphs
casio image 1-kiqbpyn3hgcftjnsgpwgpmsp-5-0.png by pressing F3 Type.casio image 2-kiqbpyn3hgcftjnsgpwgpmsp-5-1.png
Press F6 for the arrow on the right, you will get the other types
For example press F1 to select the Y greater than type graph.casio image 4-kiqbpyn3hgcftjnsgpwgpmsp-5-6.png
Notice that on the top line Graph Func: Y>. From now on all the graphs you will draw will be Y> some function in X.
Start entering the function. As you start the screen will show Y1>casio image 5-kiqbpyn3hgcftjnsgpwgpmsp-5-10.png
Enter the function for example sin(X^2). Use the X, theta, T to input the X variable.casio image 6-kiqbpyn3hgcftjnsgpwgpmsp-5-15.png
Press the EXE key to complete the function line. The screen will look like on the following screen grabcasio image 7-kiqbpyn3hgcftjnsgpwgpmsp-5-21.png
Press the F6 key Draw to get your graph and the shaded region, as on the following picture:casio image 8-kiqbpyn3hgcftjnsgpwgpmsp-5-28.png
Jun 22, 2017 | Casio FX-9750GII Graphing Calculator
Casio fx-9750gii where is the PROB button
Put the calculator in the Run>Mat screen. Press the OPTN key, then F6 to pan to the next page of tabs.The PROB tab is activated by pressing the F3 key.
Dec 03, 2012 | Casio FX9750GII Graphic Calculator
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
How do you turn frequency on when in the stats table mode on a casio fx-9750gii?
There is no such thing as turning the frequency on on the Casio calculators. Just enter your data in lists. Choose one List where you put the frequency information. When you want to GRAPH or perform CALCulations you have a TAB labeled SET corresponding to key F6:SET. When you press F6, a new screen open where you assign the list to the variables.
Here are a few screen captures to help you.
Press F2:CALC (or F1 Graph). The Tab SET appears at the bottom of screen
Press F6:SET
Higlight the line 1-Var Freq (or 2-Var Freq). The bottom of screen shows F1:1 and F2:LIST. If frequencies are not equal to 1, press F2:LIST to assign the frequency list. I entered 2.
List2 is now the frequency list.
Press EXE to perform stats.
See that n=19.
May 19, 2011 | Casio FX9750GII Graphic Calculator
How do i use the fx-300es to graph
Sorry but you cannot do that. This is not a graphing calculator. However you can generate a table of values for your function (MODE TABLE) and use it to graph the curve by hand (pencil and paper).
If you need a Casio graphing calculator, one of the cheaper ones is the Casio FX-9750GII. Equivalent Texas Instruments calculators are the TI83PLUS/TI84PLUS.
Aug 31, 2010 | Casio fx-300ES Calculator
How to grahic using casio fx-9750GII
To draw graphs.
  1. Turn calculator ON (isn't that obvious?)
  2. If you see no icons, press [MENU]
  3. Use arrow to move focus on GRAPH and press [EXE]
  4. By default, the graph type is Y=
  5. Enter your equation on line Y1=, use the [X,theta,T] key to enter the X-variable
  6. Press [EXE] when finished entering a function.
  7. Enter other functions if you want.
  8. When done, press [F6:Draw].
  9. If you do not see a big portion of the curve you can press [SHIFT] [F2:Zoom] and select [F5:Auto]
I am enclosing screen captures. The screens you see may not look exactly as on the FX-9750G, but all menu commands you have to execute are accessed by the same key sequences.
This last one is obtained with the Zoom: Auto
Mar 09, 2010 | Casio FX-9750GPlus Calculator
Casio Calculator Graphing FX 9750GII Calculator Logo
1,121 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
