Question about Hitachi Televison & Video
Where do you align the lights at, adjust? - Hitachi Televison & Video
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
A model number is needed but most older Hitachi projection sets the convergence (look in menu to see if there) and other things are adjusted with the remote. 3 d picture or what?
Posted on Nov 06, 2012
How to adjust the head light in lancer 2005
There are usually some adjustment/aligning bolts on the back of the headlight. You will have to park your car perpendicularly to a wall about 25 feet away from the car. Then you will adjust and align the bolts on the back. You will have to open the hood as the alignment bolts are on the back of the headlight which is accessible from the engine compartment side. There are usually 3 alignment bolts per headlight. You may have to chalk up a pattern on the wall when you do this. Here is one guide for you. http://www.popularmechanics.com/cars/how-to/repair/1347221
Jul 14, 2014 | 2005 Mitsubishi Lancer
Adjust headlight on harley ultra classic
Hi Larry, the correct procedure for adjusting a head light is as follows:
1. Verify correct tire inflation.
2. Place motorcycle on a level floor or pavement in an area with minimal light.
3. Point the front of the motorcycle towards a screen or wall witch is 25 feet from the axle of the front wheel.
4. Draw a horizontal line that is exactly the same height above the floor as the floor is to the center of the head light.
5. Have a person whose weight is roughly the same as that of the principal rider sit on the motorcycle seat. The weight of the rider will compress the suspension slightly.
6. Stand the motorcycle upright with both tires resting on the floor and with the front wheel held in straight alignment pointing forward.
7. Turn the Ignition/Light Key Switch to Ignition. Set the Light Switch on the left handlebar to High Beam.
8. Check the light beam for proper height alignment. The center of the main beam of light should be even with the horizontal line on the screen or wall.
9. Check the light beam for proper lateral alignment. The main beam of light should directed straight ahead i.e. equal area of light to the right and left of center.
10. The headlamp adjustment can be performed without removing the chrome ring. If the headlamp alignment requires adjustment use slots in the headlamp chrome ring to insert phillips screw driver between headlamp housing and rubber gasket. Turn the vertical adjustment screw as necessary to align the headlamp vertically. Turn the horizontal adjustment screw to adjust the headlamp horizontally. Good luck.
Aug 08, 2012 | 2009 Harley Davidson FLHTCU Ultra Classic...
Adjusting the headlight on 2005 roadking
Hi Anonymous, the correct procedure for adjusting a head light is as follows:
Jul 24, 2012 | 2005 Harley Davidson FLHRCI Road King...
How do you adjust the headlight on my harley xr1200
Hi Schnauzersru, the correct procedure for adjusting a head light is as follows:
Aug 20, 2011 | Harley Davidson XR1200 Motorcycles
2001 HD FXD headlight adjustment
INSPECTION
Verify correct front and rear tire pressure, put the motorcycle on a level floor or pavement area with minimum light, put the motorcycle 25 ft (7.6 m) away from a screen or wall measuring the distance from directly below the front axle to the base of the screen/wall, draw a horizontal line 35 in. (0.9 m) above the floor on the screen/wall, load the motorcycle with a rider, and passenger and any cargo normally on the bike when it is in use so that the weight will compress the motorcycle suspension as it would be in normal use, stand the motorcycle upright as it would be when being ridden i.e. with both tires resting on the floor or pavement and with the front wheel oriented in straight forward alignment, turn ignition the switch ON, set the handlebar headlamp switch to the HIGH beam position and then check the light beam for proper alignment. The main beam, which is a broad, flat pattern of light, should be centered equally above and below the horizontal line on the wall or screen with the light beam pointed straight ahead and when properly adjusted the headlamp will project an equal area of light to both the right and the left of center. Adjust if necessary to obtain the foregoing light pattern and placement.
ADJUSTMENT
All Models But FXDWG
Remove the snap plug on top of the headlamp housing, loosen the adjusting nut on top of the headlamp, move and adjust the headlamp to obtain the light pattern on the wall or screen as is desired, tighten the adjusting nut being careful not to move the headlamp and then recheck the alignment and re-install the plug.
FXDWG Models
Loosen the horizontal adjusting bolt so you can adjust the headlamp beam side to side, loosen the vertical adjusting bolt so you can adjust the headlamp up or down, align the headlamp to obtain the desired pattern on the screen or wall, tighten the bolts and recheck the alignment and light focus pattern.
Apr 14, 2011 | Harley Davidson FXD Dyna Super Glide...
Need to adjust the headlights on a 95 p/u
There is an adjustment screw on headlight housing which will adjust the vertical height of your lights. Best way to adjust, on a flat fairly long stretch at night, adjust lights then to ensure thats where you want them and they are aligned equally (impossible to do during daylight hours)
Dec 10, 2010 | 1995 Chevrolet Suburban
I need to replace and then adjust the headlights on my 2000 Chrysler 300M. How do I replace the headlights, then adjust them.
Park your vehicle on level ground with the headlights near a garage door or wall. A good distance is 2-3 feet away from the wall or door. The location must be perfectly level and flat at a distance of 10 to 25 feet away from the door or wall.
Switch on the low headlight beams and mark the horizontal and vertical centerlines of each headlight beams on the wall using masking tape. This will mark the center of each beam with a +. The marking will tell you where exactly the headlight beams should be centered from a distance.
Move the vehicle back about 10 to 25 feet away from the garage door or the wall.
Keep the headlights on the low beam setting.
Use the markings you made on the wall or garage door to, check where the light shines and see if the centerlines still match up with the masking tape marks. If the centerlines of the two beams do not align with the tape marks, you can adjust one or both sides as needed.
Make the necessary adjustments with the lights still on while watching the light beams on the wall and your marks.
Turning the top adjusting screws in a clockwise direction will raise the beam while counterclockwise turn will lower it.
Turning the side adjuster screws will adjust the lights to the left or right.
Continue the adjustments until the center of the light beams are aligned with the tape marks. Then adjust the vertical alignment of both beams slightly below the marks on the wall. This will assure that the lights are tilted slightly downward so they won’t blind approaching motorist.
The will align bot lights, the high and low sine both are connected to the same headlight!!
Nov 18, 2009 | 2000 Chrysler 300M
Changed passenger side headlight bulb, now unable to adjust or align head lights
Changing the bulb should not have affected the housing adjustments.
The bulb is just inserted into the headlight housing. The adjustments on the headlight housing is what adjusts the alignment of the headlights.
Did you maybe not get the bulb not seated correctly in the socket? Or didn't get the socket not seated correctly into the housing?
Aug 12, 2008 | Ford Focus Cars & Trucks
Red is off to the right while blue and green light are in sync
Convergence alignment issues are common to all rear projection
TV's....Repair requires replacement of STK IC's on large heatsink.
After repair, alignment often returns to normal......T.
Oct 27, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
