I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
  • 32,281 Answers
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Posted on Nov 06, 2012
Beni S-P
  • 1006 Answers
SOURCE: Hard Drive Data Recovery
Yess it is:
Put that hdd in another pc who have WIN XP SP2 and REMOVE JUMPER from HDD!
Download this program and recover your data:
DOWNLOAD
Posted on Dec 26, 2007
  • 79 Answers
SOURCE: my dell desktop is just making a ticking noise and won't turn on
So the computer will not post! Try these steps.
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
That covers almost everything,,
If still nothing then possibly bad Motherboard or CPU.
Brian
Posted on Jul 06, 2009
  • 82 Answers
SOURCE: Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Posted on Aug 08, 2009
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
  • 8909 Answers
SOURCE: I have a Dell Intel Pentium 4 Processor: 3.00 GHz
Go and press F2 then find Load Default or something similar as each BIOS is different.
If it then loads, change the cmos battery.
Posted on Feb 19, 2011
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Dell Dimension 1100 hard drive activity light on constantly and hard drive making noise, lagging
Try to create an other user and login with that user, then check if the issue still happen.
Jan 03, 2013 | Dell Dimension 1100 PC Desktop
Dell Dimension 2400 won't boot says press F1 continuosly and hard drive makes constant ticking noise
there could be a problem with your hard drive. I would try another one if possible.
Nov 07, 2012 | Dell Dimension 2400 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Dell monitor flashing green power button black screen.
Your computer is in sleep mode, a low power mode that conserves power by turning off the screen and hard drive.
Push the power button on the system and the computer will resume.
If you don't like this feature, you can turn off sleep mode in the power options in Control Panel
Jul 26, 2011 | Dell Dimension 2400 PC Desktop
Help me, my Dell 2400 desktop worked fine yesterday, but today it will power on to boot start up but then i get nothing else on the screen, one green light only and no fan noise. i tried unplugging and...
from your explanation it like the problem come from your motherboard, your motherboard was damaged, and you need to change the motherboard with new one
Mar 25, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 desktop. The green light goes out and an amber one comes on. The screen then goes black and I can not use the power button to reboot. I have to unplug everythhing and then it...
You most likely need to reinstall windows. Insert your windows cd or dvd into your disc drive and then reboot the computer. Make sure you backup any of your important files first.
Mar 05, 2011 | Dell Dimension 2400 PC Desktop
My dell 2400 wil run for sometimes 10 sometimes 45 minutes and the the monitor loses signal and the power light is amber and the hard drive light is green, the diag. lights in the rear are either off or...
The power supply may be going out. Go to the Dell website, select support, enter your service tag number and find your symptom to determine the problem. The lights in the back will help you isolate the issue by cross referencing it to the lights that are lit and not lit.
Nov 02, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 hit by lightning. the green
it can be one of 2 things:
1. if the battery charge light is all that comes on then you motherborad is busted.
2. if the power light turns on without the screen showing anything then you will need to replace the screen, but first connect it to an ordinary PC monitory and see if it works from there before changing anything.
Jul 18, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 Lost Password for Bios
:0 easy
1.) remove the side panel
2.) locate the battery on the main board and remove it
3.) make sure the system is unplugged
4.) press the power button and hold for 10 seconds
5.) replace battery, plug in and power on.
Apr 03, 2009 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
