Question about Dell Dimension 2400 PC Desktop
Dell Dimension 2400 won't boot says press F1 continuosly and hard drive makes constant ticking noise
  • 564 Answers
There could be a problem with your hard drive. I would try another one if possible.
Posted on Nov 07, 2012
  • 3940 Answers
SOURCE: dual monitors on my dell dimension 2400
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
Posted on May 20, 2008
  • 916 Answers
SOURCE: No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Posted on Dec 22, 2008
leecom72
  • 4806 Answers
SOURCE: How to remove the hard drive from my dell
Hi there.
Firstly remove the power cord from the back of the desktop, then turn the unit round so the back of it is facing you, on the right hand side there may be a couple of screws and plastic catches, remove the screws and lift the plastic clips so the side panel opens up, once that is done you will be able to see the motherboard, the hard drive looks like this >>>>>e340c2b.jpegnow depending on the type of dell you have there maybe screws or green plastic strips that holds the HDD in place, if you cannot get it that way then the front panel has to be removed.
If this is the case post back and I'll tell you how remove it.
Good luck and thanks for using Fixya!!!
Posted on Feb 23, 2009
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
  • 2427 Answers
SOURCE: Dell Dimension 2400 Lost Password for Bios
:0 easy
1.) remove the side panel
2.) locate the battery on the main board and remove it
3.) make sure the system is unplugged
4.) press the power button and hold for 10 seconds
5.) replace battery, plug in and power on.
Posted on Apr 03, 2009
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Nov 05, 2012 | Computers & Internet
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Can i make a bootile usb for dell dimision 2400
If the BIOS setting for the Boot up device order does not have the USB as a boot up device then it is not possible to boot up your computer with an USB device.
For a Drive 0 seek problem -
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 19, 2012 | Dell Dimension 2400 PC Desktop
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 3000 series desktop and when I turn it on it does not get passed POST and tells me the following: primary drive 0 not found primary drive 1 not found gives me the option of F1...
This normally means that the Hard Drive is not recognized, and most likely can be attributed through a crashed hard drive. If it's not POSTing, then I think you need to look for loose cords/cables as well. That can cause the hard drive to not be recognized.
Jul 07, 2011 | Dell Dimension 3000 PC Desktop
Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Apr 14, 2010 | Dell Dimension 2400 PC Desktop
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Diskette driv 0 seek failure
press f2 go to the boot priority and select harddrive to the first boot.
Nov 22, 2008 | Dell Dimension C521 PC Desktop
Dell Dimension 2400 PC Desktop Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
