Question about Presto HeatDish Compact Heater
Once it heats up the warning blaring sound comes on
This is the older model without the footlight. It heats up well, but left on, it will give out the loud warning blare that is designed to go off if you bump into when it is on. Turning it off or down very low makes the sound go away, but then it comes back on as it heats up again. I think the signal switch or something must be bad. Can I fix this? Or disable the warning buzzer?
    Problem Solver:
  • 4 Answers
Had a similar issue. I think if you pull the plug, remove the cover (about 4X6) inches and inspect all wires and connections you will find your culprit. Look for evidence of arcing at a connection. If evidence of arcing is present the terminal must be thouroughly cleaned and maybe a new lug attached to the wire.
ddr_2u@charter.net
Posted on Jan 13, 2009
Screen wont turn on
Hi Eric,
Sometime we can find solution from the very basic. How about to adjust brightness of your screen by using keypad?
May 01, 2014 | Gateway NV5378u Notebook
My xbox 360 slim wont turn on. the system makes the beep indicating power and the light comes on...then goes off all together.plzzz help me
yeah sames happening with mines, like 2 days ago it kept restarting without warning, i looked up online and people were saying the hard drive might be loose so i took it out and put it back in, and it was fine, this morning i turned it on and was playing for about 2 hours when it did it again, once again i looked it up and aparently its over heating, so ive left it for about 6 hours now and it wont turn on at all :/
Dec 12, 2010 | Computers & Internet
Dell XPS 200 Computer shuts off leaving blinking amber light
3 most common solutions to your problem are:
  1. Bad power supply; once it heats up will quit without warning
  2. Bad heatsink/fan; processor heats up and will lock up your Pc
  3. Bad motherboard
Try opening the machine and give the inside a thorough cleaning, paying special attention to the heatsink and fan. Once clean and you've ensured the fan is operating, put it back together and see if your problem is fixed. If not, a new power supply will likely fix your problem. Best of luck.
Greg
Jul 06, 2009 | Computers & Internet
Microwave not heating food
It's most likely the Magnetron. The are not very easy to install and quite expensive. Older models magnetrons cost about 80 bucks from GE. It's probably not something you would want to try and repair yourself. Call a GE service person.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Presto HeatDish Plus Footlight - Parabolic Electric Heater Where can I find these??? They are great.
http://www.gopresto.com
Or try a thrift store for a used one. Do a search for "heat dish" without the quotes, and you will get a few hits. Amazon.com has a few of this type of heater.
Aug 18, 2008 | Heating & Cooling
Presto Heat Dish w/footlight
This heater must be flat on the floor or it will buzz, and the metal dish must be clean or it will transfer heat to the safety device. If this does not solve the problem call customer service at 800-877-0441.
Jun 14, 2008 | Presto Heat Dish/Electric Heater with...
No sound when first turned on.
i have an amplifier ONKIO too and my generation is older than yours but i'm the same probleme and it's normal if you use this amplifier to your speakers. the internal switch must be heat to give a normal sound without distorsion. it's the principal problem of the onkio amplifier but after the quality of thr sound is great
so take the time and be patient now you know you have to start on your amplifier 5mn before use :)
Jan 18, 2008 | Onkyo TX-SR502 Receiver
Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
Feb 21, 2007 | Vizio L37 Television
Presto HeatDish Compact Heater Logo
149 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
