Question about Samsung HP-R5052 50 in. Plasma HDTV
Hi, I switched off my Samsung TV last night as usual, and when I tried to switch it on this evening it wouldn't switch on.I tried unplugging it and turning it on, but the red power light on the b
My tv model code: PS51D550C1RXXA SERIAL NO: 276039NBB01604V VERSION:1406
    Top Expert:
  • Samsung Master
  • 14,553 Answers
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. Hi, I switched off my Samsung TV last night as usu - 11_6_2012_3_22_05_pm.jpg
Posted on Nov 06, 2012
melnavz
  • 1226 Answers
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
Posted on Mar 03, 2008
  • 98 Answers
SOURCE: TV not switching on
Can you hear the sound of turning on?
I think that you need to replace the main board.
Posted on Feb 09, 2009
  • 304 Answers
SOURCE: samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
freetek
  • 5568 Answers
SOURCE: Samsung FPT 5084X won't turn on
Sorry, but welcome to the world of highly efficient, component-critical switching power supplies.
These are all of those things and the failure often is related to a specific type of component, an electrolytic capacitor. These are chemical devices and cheap ones fail easily, the most expensive take little longer but the primary value shrinks while the losses climb until the part cannot do what it should any more.
The main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Aug 27, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
There is no power at all. Last night the TV kept switching itself back on after being switched off. Now today nothing.
Unplug the tv for at least a minute and try again. or you may have lost your power supply on the tv, usually just a cap gets fried and can be fixed fairly easily with some soldering experience.
Apr 11, 2013 | Sanyo DP50747 50 in. Plasma TV
AH59-02402A REMOTE, WAS WORKING FINE LAST NIGHT AND EVEN THOUGH THE LIGHTS BLINKED ON IT I TRIED NEW BATTERIES STILL WILL NOT CONTROL BOX???
If it show it was doing updates, Thats probably why it wouldn,t work .Once it has updated ,IT will (Probaly) Work (Again)
Nov 07, 2012 | Televison & Video
Samsung TV
Based on the information you described you may have a tuner
circuit problem or power intermitent faikure fron the power supply module.
Nov 02, 2012 | Samsung Televison & Video
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Samsung Plasma model ps-50p91fd red light flashing will not turn on can hear clicking as if going to switch on but nothing happens just switched off last night problem occured this morning
Hi:
First thing you should do is unplug the unit from the AC outlet and wait 5 minutes before pluging it back in. IF this does not solve your problem, then you should the unit serviced. The most common failure part in plasma's are the y-substain board and the power supply, have these check for shorted conditions.
Sep 09, 2011 | Samsung Televison & Video
My AVEiS 26" TV has
Your TV needs software upgrade. If you have usb port on this. Check the manufacturer's website for the TV softwar, download it. Copy it on pen-drive. Plug into usb port & follow the procedure as per the user manual to upgrade the software.
If the problem is not solved, then it needs repairs in its analog switching section.
sonsunny
Jun 17, 2011 | Televison & Video
We've had a 42"
Sounds like the powersupply is bad. Try replacing that. Hope this helps.
May 25, 2011 | Televison & Video
LC320EM8A 32" TV WON'T COME ON NOT BY REMOTE (NEW BATTS) NOT BY TOP POWER SWITCH. WORKED LAST NIGHT NOW NOTHING, TRIED THE ONE SUGGESTION IN MANUAL TO UNPLUG FOR 30 MINS TO RESET(?) ALL POWER CONNS...
Hi Wayne,
I'm glad your getting somewhere with your research. If you arent getting even a standby light, try checking the plug fuse and if this is ok, then the power supply board inside the tv is faulty. Could even be the power pcb fuse or dry capacitors (bulging tops on faulty ones). Hope this helps, and good luck :)
Feb 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred...
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Nov 08, 2009 | Toshiba 36A43 36" TV
Samsung HP-R5052 50 in. Plasma HDTV Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
