Question about Freud FT2000E 3 Router
Freud 3 one fourth plunge router variable speed won't run
Just statred to run for a second and stopped
  • Anonymous Mar 25, 2014
    freud router ft2200 stops working under load
  • 211 Answers
First check the power suply cord(conductivity),the on/off switch, the fan and the armature,the brushes and the wires.
best regards savumihai71
Posted on Feb 12, 2009
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Mar 23, 2014 | Freud FT2000E 3 Router
Dw621 pulsing speed problem
Try to start it at various speeds. Use contact cleaner on the switch, and the variable speed control resistor.
Mar 02, 2014 | Dewalt DW621 2 HP Evs Plunge Router W/...
Router schematics
Hi I am a dealer for freud in Canada .Do you still need the schematics if so give me your email and I will send you one no charge.
Jan 17, 2014 | Freud FT1700VCEK 2 1/4 Horsepower Variable...
I need a 1/4 collect for FT 2000e Freud plunge router, where can I buy it?
Hello Freddie--my name is Larry Boccioletti. I am a Freud parts supplier from Toronto Canada.It is almost impossible to get parts from Freud in the states---because Bosch has bought them out.
I have parts for the ft2000 and FT3000.
If you would like a quote I would be happy to get one for you.
just send me an email to
Apr 06, 2013 | Freud FT2000E 3 Router
I have a Freud 2000E plunge router. It is about 10 years old, but I've never changed the router bit I have in it before. Now I want to remove the bit I have in, but cannot turn the bolt to remove it....
Hello Davis gr,My name is larry I am an auth Freud service tech.
The first thing to do before you attempt any repairs is of course to unplug.In the full plunged position make sure the router is locked in position out of the table on its side.You twist to loosen the bit nut
and tap gently on the side of the bit with a rubber hammer
turning it slowly and it will come loose to remove.
second--If the router will not spring up to its top position it is because
the posts that are spring loaded are dry.again you must remove the router from the table clean the postd with a dry cloth and while still locked lubricate with lite oil using a clean cloth the metel posts.
after that with the same rubber hammer tap the base plate and it will come loose
I hope this is some help
Larry in Canada
Sep 11, 2011 | Freud FT3000VCE Router
I have taken my FT 2000 E to my local saw shop for repair because it would not run. They diagnosed the problem as a faulty speed control switch. After attempting to get the part from Freud twice and...
I have a FT2200 with a bad speed control unit 76348.
8015. Freud no longer supplies this part. I bypassed it, and I am using an external variable speed control supply. The only setback is there is no longer "Torque Control". This presents a problem if the bit burns, but I control the speed of feed. So for, I am getting by. A new one is TOO expensive.
Jun 21, 2011 | Freud FT2000E 3 Router
You can order your switch from Freud at (800) 334-4107. It is number 42 on the parts breakdown which you access at:
Freud's part number is 76325.7001
It doesn't seem like anyone stocks Freud parts. Went to some discussion sites and found that even repair centers don't stock them. You'll have to contact them directly.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 08, 2011 | Freud FT2000E 3 Router
How do I remove the base of a Freud FT2000e router so that I can remove the plunge springs?
Hi There, My name is Larry --I am a FREUD DEALER IN CANADA
To answer your question about the router springs.You must first remove the cap carefully to prevent any damage to the speed module. Under the cap you will find two nuts first lock the base and leave about 2 inches for a socket to go over the nut .Remove normally and be careful when you release the base do it slowly it will spring up fast and hard --
Nov 13, 2010 | Freud FT2000E 3 Router
My Ft2000E Freud router stopped working when I was setting up to run some moldiings. No humming . no burning= nothing. Any Ideas?
Hello Blonsan I am a service dealer in Canada and the speed control will do that no warnings ---the speed control is 89.00 canadian ---give or take--
Nov 04, 2010 | Freud FT2000E 3 Router
Variable speed switch FERM ROUTER
the variable switch had 5 connection points on it, i bridged the connection on the 2 outer points with insulated wire,pretty much to see what would happen, this worked,
as this will be a router fitted to a table i will at some point remove the wire and
attach a 5way rotary switch, used for guitar electrics and mount it
into a electrical switch casing,
Oct 10, 2008 | Freud Tools & Hardware - Others
Freud FT2000E 3 Router Logo
533 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
