Question about RTO Aqua Pro Systems Pro 600 60,000 BTU Heat Pump w/ Cupro Nickel Hx
Display showing codes psd and 147 on display...heater is not starting at all...waht does it mean and what to do?
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Tankless water heater model # RTGL74PVN is blinking 38 what does this mean
Copy following link for general troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Tankless Hot Water Heater...
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
What does error code r =8 at startup mean? Turned heater on for first time this year. Opened gas valve at tank and shut-off at heater. Pump is running. Turned 220 v breaker on in box and "spa on"...
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Warning psd mg
hello there!
you must disassemble the camera and blow air aiming the ccd block area in the backside of the the lens with a duster spray by means :REMOVE THE LENS AND BLOW AIR FROM 20 cm distance,then reassemble the camera thoroughly and please do not use excessive force while doing it,mini DV camcorders are sensitive in handling ATTENTION qualified personnel only
Dec 20, 2009 | Panasonic AG-DVC62 Mini DV Digital...
If i have wordpress theme psd file i mean photoshop file can i upload the theme via my word press control panel or i need some more files including psd file to make my theme work in word press. i will...
hi,
listen your psd file is only an image file. just uploading that wont make ur theme available in ur wordpress. you have to design your theme with HTML and CSS just like the one u see on the psd file. that is with reference u have to design it and then upload the html file , images and css to make ur theme available.
Nov 15, 2009 | Computers & Internet
Showing warning psd ng in dvx102 panasonic video cam
PSD NG means that there is a problem with your electronic image stabilization system.I think Panasonic got stuck with a bad batch of gyros. Take it back if you can, otherwise use lower resolution or hold very still when filming.
Mar 26, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
RTO Aqua Pro Systems Pro 600 60,000 BTU Heat Pump w/ Cupro Nickel Hx Logo
71 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
