Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Error code 3503
Pictures have no black ink.
Konica minolta bizhub 950 report code c-3503
Reset the soft switch 3-1 to 0. Code is for a problem with the fuser the hot part. once reset. if the code comes back have a technician look at it because constantly resetting could cause a fire! that would ruin a perfectly good day!!!!!
Dec 12, 2013 | Minolta bizhub 350 Black and White Copier
Fusing high temperature abnormality.Check the connections and the relevant electrical components(thermistors,thermofuses,heater lamps).
Clear error code
Go to service mode soft switch set first box to three second box to 1 change box 3 to 0. If the code comes back do not reset the machine is indicating it is broken doing so could cause a fire. The code that is being displayed state the fuser the hot part is over heating.
Nov 07, 2013 | Konica Minolta Bizhub 600 750 Image...
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
Aug 11, 2013 | Xerox Phaser 8500/DN Printer
Navigator GPS 3503 user manual
Try
www.tempoaustralia.com.au/GPS3503
this gives the full manual but the pictures are missing?
May 16, 2010 | GPS
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
204 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
